hey, nah i dnt need it asap, well jst tell me ok? if no1 wants the shell =) and also interested in ur dash surround, the one thats silver in colour? and your intercooler tell me if its in pretty good nick as well.
  • Replies 130
Posted Images
STILL waiting on pics of front pipe!
Can everyone reading this posting PLEASE go to the feedback/suggestions topic at the bottom of the forums main menu and give your support to the 'no-posting-an-item-for-sale-without-a-pic-of-that-item' post?
Thanks.
Thanks.
how about you learn the art of patience. if you read what he said earlier you'll see he only JUST got the wreck back to his house from insurance. if you're that desperate for the front pipe go and buy a new one, otherwise sit and wait until he gets the photo. i've personally seen this guys phone non stop ringing from people wanting parts off it. personally i dont support the no posting an item for sale without photo crap because of situations like this, where not everything needs a photo. it's a whole car he's wrecking so whats he meant to do, take a photo of every single component of the car and post it. i reckon thats a bit of a waste of time.
not trying to have a go at u... but it's just annoying seeing people whinge like that!
Just impatient. Sorry mate.
I've been busting for a front pipe for ages now, that's why I'm eager.
Sorry mook! Don't mean to get antsy about it, but it is frustrating waiting for pics. I'm sure you have a lot of people waiting.
yeah thats cool mate. if you must know i took that front pipe off for mook today the lazy bastard, and its in pretty good condition. small bump on the bottom, nothing to really worry about. he's working on getting pics up but cant upload them to his computer.
Cool.
Well, I may have already arranged for another front pipe, but send me
pics of the item when you can anyway, you never know what's going to
happen.
Thanks again for understanding,
Adrian.
  mook1 said:
Hi i was wondering if you a powersteering pump for a 95 S1 GTS-T if so how much and can you let me know @ wtiburcy@bigpond.net.au
Thank you Bill
sweet. PM me a price for the visors :P
Im after the thing with all the switches. The bit that fits to the door handle arm rest thingy.(wish I had a pic!!)
Also, how much for the RHS rear tail light cluster?
Cheers.
PS - also after RHS mirror. :P
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
