Padded R33 7 Point Cage
yes i've always measure point by how many places it bolts to/is welded to the car. BUT cusco/safety 21 cages are measure by the bolt points, and the rear bars, or maybe the just count the number of bars. so your would be a 7 point in their lingo either way. add the bar that runs straight across the bottom and they call it an 8 point.
is this for one with a sunroof or no sunroof, i guess the interior needs to be removed to fit it?
ben...
I am unsure about the sunroof but i assume it would fit as the front crossover bar is right towards the front and i dont think it would interfer with a sunroof. And no the interior does not have to come out, however the rear cross bar needs to be removed to seat passengers in the back seat. And doesnt affect dash at all...
Yes there is no lower bar on this cage so you could call it a 6 or 7 point cage. Comes with all mounting bolts would like to sell asap to finishes repairs on skyline...thankyou
 Share
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
