Recently my R33 Gtst has developed a knock sound in the front left suspension after coming to a stop, and then taking off again. It just a single knock which doesnt re-appear until the next time I *stop/start* again. I assume that its a worn bush somewhere but cant really work out which one it is.
Anyone care to suggest how I can fix this or have a similar problem?
https://www.sau.com.au/forums/topic/108128-do-i-need-new-bushes/
I have a similar problem. When I stop there is a rubbing up sound and when I take off there is a rubbing sound again. My sounds have been more prominent now that i have changed my tie rod ends (you can see my article in the Tutorials section). If this is the problem for me, I am upgrading to the Fulcrum Neoprene bushes and changing them myself =)
Good luck PM if you get any information.
Oh and to answer your question, the bushes that im talking about is on the Castor Rod.
Edited by arbess
If the R33 front suspension upper arms are anything like the R32 ones, they can clunk when they are really stuffed, the first set I replaced on my R32 squeaked for ages then developed a clunking sound, another possibility can be the big nut that holds the shock in the strut can be loose and cause a banging noise, this happened to my R31 when the 'apprentice' that fitted my front shocks failed to tighten the strut 'nut' tight enough (they were fitted by the car dealer to pass a roadworthy! - normally I would have done it myself.)
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
