Hey guys, whilst driving along the motorway today i noticed my car riding in "d" gear, it got worst and worst and before i knew it, i could barely go up to 30km....the revs would just fly up, and fly straight down, as if in neutral.....what does this mean, it feels as though it jams up in 3rd and doesnt want to go into 4th???
BTW 1st and 2nd are running fine, 2nd gear was wat i used to get bak home, as i revved higher but it was moving unlike "d".
https://www.sau.com.au/forums/topic/108141-auto-gearbox-kapoot/
the auto's for a r33 are generally pretty cheap. They usually are sold for around the $300 mark i think. Manual conversion would be a lot more expensive (about $3000 so cheaper to sell auto skyline and buy a manual one).
If you want something in between those two figures maybe re-build the auto with stronger internals and a new valvebody etc.
just courious, how many RWKWs could the stock GTST AUTO box take before it breaks?
Chris
Around 250rwkw (or a turbo upgrade) and you'll be wanting to strengthen the box with a bigger transmission cooler.
i just done a auto conversion on my r33 and cost 4500, gone are the days of the 3000 conversion. i am selling my auto to luket01 at the moment for a spare. i can get hold of him and see if he still wants it?
the box is at xspeed and will require picking up from there if he does'nt want it .
sorry probly to far away, in w.a
Edited by Pal
cheers, well before any of this happened, i was going to fix up my car a little and sell it, so im really looking for the cheapest alternative, which would be to buy a 25t auto box (~300) and replace, correct?how much would labour cost for such a job?
also im going to have around 200rwkw, will the stock auto box handle this sort of power easy?
im about to replace the whole gearbox with a 2nd hand one, 500 all up inc labour, though i've been told that i'll need 7L of atf fluid???, i only filled 4L after draining mine, the guy said that its ~4L for the Transmission, and around 2-3L fluid needed for the torque converter???
everyone i heard says around 4L is right
He is right, you'll need at least 7l if the trans an convertor have been drained. Just out of curiosity, did it just go all of a sudden etc, and is it making any nasty noises in any of the other gears?
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
