Nissan Stagea WGNC34 Parts Guide
Suspension
Front Shock Absorbers - R33 GT-R
Rear Shock Absorbers - R33 GTS-T
Front Springs - R33 GT-R
Rear Springs - Unique (hopefully details soon)
Front Sway bar - R33 GT-R
Rear Sway bar - R33 GT-R
Brake Pads
Front Brake Pads - ???
Rear Brake Pads - DB1144 (same as R31)
Front Rotors - ???
Rear Rotors - ???
Front brake Union bolts - 46356OE000
Body Parts
Clear Side Indicators - RNC40 from www.nismo.com.au
Series One Clear Front Indicators - ???
Performance Parts
Air Filter - Same as Commodore A360 (Ryco Part Number)
General Maintenance (mainly same as R33)
Oil Filter - Ryco Z145A / Valvoline V04
RYCO Fuel Filter Part Number: Z201
Fuel filter also RFF4 (Repco
Spark Plugs - NGK BCPR7ES (copper, gapped to 0.8 mm)
Headlight Bulbs - Normal H4 type
Brake Fluid - Castrol SRF
Radiator - Castrol Anit-Freeze Anti-Boil
Recommended Oils:
Motul Turbo Light
Castrol Formula R Synthetic 10W60 or 0W40
Diffs - Castrol SAF-XA 75W140
4WD Transfer = Castrol Transmax Z
Auto Gearbox= Castrol Transmax Z
Spark plugs (high speed) = NGK BCPR7ES (copper, gapped to 0.8 mm) ~$20 per set of 6.
Low speed = 1 range hotter, traffic = 2 ranges hotter.
Nissan genuine cam belt part # 13028-5L-327
Radiator Part number is: NIS039C/AK ADRAD COMP ASS.
Tie rod ends - part number - 4852023U26
Part number for front Series 2 Nissan pads is : 41060AT30J
https://www.sau.com.au/forums/topic/108151-parts-list/
