Hey everyone..
tried to search for this topic, and dont think anyone would make a topic like this anyways..
I will be buying a RSM soon, and was wondering where i should mount it into a r33..
If you got any pics or ideas please post them up..
But i really would like to see some pics!!
I know it should be personal choice, but i would like to see something first.. Also how did you attach it to that position..
Thank you very much
Cheers..
https://www.sau.com.au/forums/topic/108185-where-to-mount-rsm-r33/
A friend of mine mounted it in front of cluster, but it sort of blocks most of the thing.. I know the RSM will show the speed etc etc.. but for some reason i dont like it..
But yea, anyone got a pic of it mounted on dash, middle-above air con??
WOnt get the RSM till thursday, so in the mean time, would just like to see where you all have mounted it..
thanks all..
Edited by siddr20
Not a RSM but close enough :)
As you can see I've got the Apexi stand too - not sure if you have it but it makes mounting these devices so much easier.
When I'm parked outside of my house I use a beanie to cover it up so people can't see it from the outside.
hmm i like where you put your safc wink.. might put mine in the same spot.. Did you use double sided tape?? hahah yea, i might have to put a hat or something to cover it up.. only disadvantage..
howd you mount yours secur1ty??
I used 4 squares of cheapo DS tape for the base and I used the DS tape that came with my GReddy Profec EBC to stick the SAFC onto the stand. I used to use the cheapo tape for that but it melts under the sun very easily.
On that note, with it mounted on the dash like that, the RSM will be exposed to lots of sunlight so make sure you cover it up when you are parking in exposed areas.
lexbomb-any chance of pics?? keen to see how it would look there.. wouldnt it be hard to read--while driving??
ctjet- hmm i think the rsm is way longer than the asktrays lenght..but i will fiddle around with it, before puttin it in a fixed position..
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
