I've put my AVCR in the same place as mr crust, but not quite as neat (the cable isn't tucked into the ash tray). I've got it stuck on with heavy duty velcro so I can take it off and hide it under the floor mat if I'm parked somewhere dodgy (like a shopping center :) ) I just have to remember not to step on it when I get back in the car!
A friend of mine mounted it in front of cluster, but it sort of blocks most of the thing.. I know the RSM will show the speed etc etc.. but for some reason i dont like it..
But yea, anyone got a pic of it mounted on dash, middle-above air con??
WOnt get the RSM till thursday, so in the mean time, would just like to see where you all have mounted it..
thanks all..
Logical spot end of centre console under radio etc. I'd watch out on dash mounting a lot of heat there when parking during the day. The dash mounting looks a bit tacky.post-25792-1142508570.jpg
gotta agree the dash looks the best, however for security reasons its not the best place.. my mate had his windscreen smashed and his nice big blue apexi unit ripped out.. they didnt get anything else, just the apexi..
Keep this in mind if you park in dark carparks at night time for long periods..
-JD
I guess, no matter where you mount it, somone will always smash the window, and steal it..
But now this has got me thinking, if someone wants to pull it out, how is it possible?? Otherwise they would snap the cables somehow..
I will try and post a pic up..
4door32-- try some sponsers who sell them.. BUt you wont be able to get same price as i told you on pms.. But atleast it will be brand new lol.. gd luck..
Hey Wink - who did you SAFC install, it looks HAWT :)
Anyways, I haven't got an RSM (need one though) but I've got the SAFC2 in my R34. Below is a few pics of where I put it in relation to my centre console.
As you can see it's not a perfect fit in the R34 ashtray area but the angle that I've put it on is perfect for my line of sight while driving (it's pointed towards the driver). Also, there is absolutely no interference from sunlight/glare as it's all the way down the bottom.
Another thing is that the face of my SAFC2 is black (D1 Limited Edition) so at night time, it doesn't look like there is anything special there at all :huh: Security benefit!
Need installation advice / tips / faq, click below:
http://satan.p5.org.uk/safc2.html
I was thinkin of that spot as well satanic, but then thought, it wouldnt be safe lookin down each time, and quickly lookin back up.. as compared to have it straight in front of you(cluster area)..
But either way, everyone likes to have it in different places..
Looks like a few ppl are keen on buyin a rsm.. why not make a group buy someone??
Well my only reason for the RSM is to remove that speed cut of 180kmh from the car... I don't need any other function of the RSM (maybe the G-sensor for wank factor)
$250 is what RSMs go for second hand... $80 is what the Pivot Speed Meter goes for - same thing, less rice. Maybe I'll just opt for that, though having another "computer" in the car is cool :D
Ahh so the rsm does remove the speed cut...
or does it just display the speed, above whateva speeds u doin of 180.. while the normal guage will just sit at 180??
heheh well i got it an excellent price if u say if they go for 250.. thanks mr_g.. heheh..
I mounted mine just under the aircon unit, in a empty fold down single din pocket i got for like $30-$35(off another forum member, they came off the x-trial i think hence the colour) i can't remember, its no longer fold down because i broke it hahah so i put velcro to hold the cover on instead.
mine is for the avc-r, but same size as rsm/safc.
Cover On:
Cover Off:
Wow thats hi-tech man..
so the rsm hides in the pocket??
Man i wouldnt mind havin that for my boost controller..
can you post pics, of it half way in, half way out.. any more brighter pics man..
thats a really good idea.. i like it..
Its actually my Boost controller (AVC-R) not RSM,
i just use it to check the peak boost/speed/rev i just hit, and change my low-high boost settings.
unfortunately thats how it sits (a little in) had to modify the pocket(cut a hole in the top of it) for the avc-r to fit.
its actually better now with the flap broken because when it was attached(working) when its open its still there only folded down.
MAIN objective was to keep it visable and hide it when i park my car in the carparks. inside of having it infront of the ash tray.
Would anyone have instruction manual for the rsm??
Cant find it on net, nor does the apexi website contain one.. There was a link to it, but says, error link moved or something..
Found a manual for some older version of rsm i think..
so anyways if someone could please send it to me, it would be greatful!!
cheers..
It is possible to remove an AVCR with out snapping the cable. The cable coming off the back of the AVCR plugs into another cable that comes from the harness, solenoid and pressure sensor. The manual instructs you to push this connection though the firewall of the car so someone could just unplug this and take your AVCR. I guess if you didn't feed this plug through the firewall it would be a lot harder to nick it.
I don't know if this applies to RSM's however.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
