Well they say the proof is in the pudding.
I had a lazy syncro in my R32 GTR. On the down shift from 5th to 4th the only way I could engage with out a gear crash was to double clutch and spike the revs to 4000. Anything less than that and "CRUNCH".
The change from 3rd to 4th was fine as long as the change was not rushed.
Choice - Medication or surgery?
Spoke to Stu who pointed me onto the "Redline" product range. Thanks Stu youve saved me a bucket of work and not to mention money.
4 Ltrs of Redline "Lightweight Shockproof" gear oil later and I now have silky smooth box. No kidding this stuff really works. I can't crash the gears if I try now. 3rd to 4th I can jam it through and not a sign of gear clash.
Id recommend this product to anyone having similar problems which I understand is a common issue with import R32's.
If you are interested in the science behind how it works it quite simple really. Most oils contain friction modifyers. Thats great for the teath of the gears and the roll shafts but does not help a wearing syncro at all. Syncros by nature use friction to work. In a nut shell, if the oil is too slippery the syncros struggle to do their job (Im talking worn parts here). Redline has reduced the friction modifyer content but replaced that with synthetics to improve gear wearing characteristics.
Woww great stuff.
Cheers
Edited by Bov
https://www.sau.com.au/forums/topic/108186-redline-experience/
4 Ltrs of Redline "Lightweight Shockproof" gear oil later and I now have silky smooth box. No kidding this stuff really works. I can crash the gears if I try now. 3rd to 4th I can jam it through and not a sign of gear clash.
Woww great stuff.
Cheers
Yeah, top stuff! It kept my stock box together for as long as it did. I use it in my dog box, drives like a stocker (well kinda hahaha).
I use a 50/50 mix of lightweight and heavyweight shockproof oil. The 9 sec supra guys in the US use a 50/50 mix in there stock 6 speed getrags.
I spoke to the Aus redline tech support, they said it was fine to mix. Worth while for any box, in a car running more power from stock.
Well worth the money... much cheaper than a new box or a re-build.
EDIT:
I actually had a chance to have a chatt with one of the owners/ sales rep of redline at Bursons on argyle st. He was very informative and loved to chatt about cars and the product. They claim 30% extended component life with thy're engine oil product, as well as some big claims about they're G-Box oil's, diff oils's and water treatment. They have a performance product for allmost any application on or around your car. If you wan't any more info, go see Tony at Bursons in argyle st.
I recon I'll be switching from Motul Crono to they're performance oils, I allready use they're water treatment ( knocked 12 degrees off consistantly at the end of every run and if you have water temp/ign correction table set up right you can pick up a little more hp when it's hot, e.g. dragracing.) and the 50/50 mix of g-box oil in my dogbox.
Anything that is used and proven with V8 supercars can't be a bad thing.
Edited by XRATED
  • 3 years later...
hey sorry to drag up an old thread. But is this redline stuff like a addtive or a full replacment oil. so i just buy a 4L bottle of it dump my oil in my box now and refill it with this?? also dose it come in all diffrent weights? or just the one weight?
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
