Myself and hoonz are going to be heading down to Wakefield for an open practice day this Friday (28th June)...
We would love to have some other SAU peeps there to burn up the asphalt with us!!!
Not many details for me to tell you other than the following:
No-one has booked out the day, it's a Wakefield Park-organised "open day" where any cars (cars only) can practice...
Costs:
* $71.50 for the day
* $27.50 for a Wakefield Clubcomp Licence valid for 12 months
* Helmet hire available for $20 per day with a $50 Deposit
For more information, and details on how to get to Wakefield, goto http://www.wakefieldpark.com.au/site/frameset.cfm
You can call me on 0418881113 :(
Hope to see you there!
Andrew. :uh-huh:
https://www.sau.com.au/forums/topic/1082-wakefield-this-friday-28th-june/
DAMNIT!!!!!!
I just checked the Wakefield web site.
They have changed it to a RACE cars only day (instead of street cars only). How rude of them.
This has now really pissed me off, which means everybody's plans to go down are now screwed up.
NO MORE TRACK DAY TOMORROW :):mad: :mad:
I just called Wakefield Park.
M: What the hell is going on? I just went to your website and it says tomorrow is now race cars only... You can't just change the calendar like that. We've all taken the day off work and cancelled other commitments and now you just go and change it to race cars only!"
W: uh ah... uh... well... uh... yeah... we don't usually change it like that, but there are all these british touring cars here and we didn't realise that there were so many and they need to practice and uh... eh...ah..."
M: Well screw that... You can't just change the day like that... Are you going to reimburse us all our day's pay?"
W: um... ah... eh... what cars do you guys have?
M: Skylines, Silvias, stuff like that... They're not race cars if that's what you're thinking...
W: well.............. I suppose you could come alo
M: NO... I'm not going to interfere with the race drivers' practice session... I'm not going to screw them around like you screwed us around"
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
