hey i was interested into putting some sound into my stock skyline r33 gts25t.
need to know if screamer pipes are any good besides a 3" turbo back exhaust.
i was told that i am able to bolt this on to my stock exhaust system while i save for a 3" turbo back exhaust system... that true?
btw does anyone know any sites that have the sound of a screamer pipe installed to a r33?
i can get a custom built bolt on screamer pipe but if i were to buy it at a shop does anyone know how much i am looking at?
thanx
https://www.sau.com.au/forums/topic/108202-are-screamer-pipes-any-good/
  • Replies 82
Posted Images
thanx
on a 33 gtst running 200rwkw installing a screamer pipe lost 5kw at the back wheels! they sound mad but will slow your car down. They are also illeagle in vic on street cars and the cops are getting more and more cluey about em, to the point they will take digital photos of your exahuast system if they are unsure.
I have seen a few for sale on ebay and also in the 4 sale forum in this site!
all the best
You can do it with an internally waste-gated system. There are screamer pipes that are of the same flange-design as the split dump pipes. The only difference is that instead of the wastegate side rejoining the split dump further down, it just vents to the atmosphere.
Pretty sure they're illegal in NSW too... and i'm not sure if you would get any gain going that way rather than a nice split dump.
yea thats the way im going for... a split dumpipe connected to it
but does anyone know for sure if screamer pipes are illegal or not in NSW? I know in Victoria their not.
Also if i were to drive with a screamer pipe... if i were not to rev my car very high... isnt that the possible way to controlling the screamer pipe
making it not go so loud??
Your car will sound silly with a loud ass screamer and stock exhaust... Spend your money on a decent 3 inch system and highflow cat.. In that time you can decide wether a screamer is best for your application.. If you have'nt got a pod. Get one. Increrases induction noise
Just my opinion (which is inline with what alot of the others are saying)
You can get a screamer dump that will fit up to the stock turbo, typically the splitter in these dumps is not a tight fit in the back of the turbo so your car will sound like it has a constant exhaust leak (because it does) even when driving around normally.
If you have a stock exhaust you may see a power increase because you are allowing the excess exhaust gas to bypass the restictive stock cat converter and mufflers. If you have a decent 3-3.5" exhaust with a decent cat you will see no gain as the exhaust will easilly outflow what the stock setup can push through it.
They are highly illegal for both noise and emmisions reasons in NSW.
Some sound nice, some sound like arse (mine sounded like arse), you will also be surprised how early the wastegate starts to open which means alot of noise everytime you come on boost which gets very annoying very quickly if your car is daily driven.
My personal opinion is put the money towards a catback exhaust first, then get the cat and a front/dump pipe. As i've said earlier, there will be no gains from a screamer once you do this.
Edited by BHDave
Yep his right......best to wait till u have a aftermarket turbo
Cut straight to the chase.
Sorry to spoil your fun mate, but you cant just "bolt on " a screamer pipe to your standard R33. You need to get a turbo thats externally gated, not internal like the stock one. Then you can hook up a screamer pipe..
Sorry..
actually, sorry, but you can have them on internally gated turbos :) makes no real difference really, probably just easier with the external gate.
And, they are obscenely loud, aren't they Jeff? ;)
Anyway, just get propper dump/front pipe made with the wastegate pipe coming in after a certain length, there is a thread on this somewhere, quieter and keeps the EPA off your ass (hefty fines too, i think $15000 if you are caught, not 100% certain on this though).
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
