The thing i always find it funny on here is people say, "its federal law, and its illegal" but how many people's car break the laws here, or break the laws in their cars.. i dont think anyone could say they dont.
Most of us obey the spirit of the law, even if they don't always manage to match the letter of the law.
Emissions laws are there to protect the environment - while its one thing to run the car a bit less fuel efficiently to chase more power so it produces more carbon dioxide, its something else entirely to dump poisonous chemicals directly into the air. Its even worse since its a street car, and so there are innocent people breathing in that shit.
  • Replies 82
Posted Images
yea i was planning on installing a bov onto my car...
the gfb bovus maximus but it seems that the ssqbov is pretty popular
once i install my 3" turboback exhaust i will plumback the screamer pipe
jus wanted to have some fun with some noise
Here is a video of [M SPEC]'s 33, with an internally gated HKS 2535.
http://s32.yousendit.com/d.aspx?id=2LCEAIW...V70PE2GEKSDPPW1
This link will expire in 7 days.
:P
No, that car does not have an Internally gated 2535 at all... please make sure you dont post misleading stuff about someone else's car.
The turbo at the time was modded to remove the int gate to run a bigger external gate.
The turbo has since died (at calder) and is being replaced with a 3037
You've never done a burnout thats made smoke for "innocent" people to breathe in before? Im not having a go at you, but if anyone gets a wiff of your gas after your external gate has opened, its hardly going to harm them..
  • 2 years later...
does anyone have any sound or video clips or screamer pipes?
i dunno bout screamer pipes but see if you like this, its 3 inch straight out the side. infront of the rear wheel.
http://au.youtube.com/watch?v=C4pm7OvTqco
awww.. so no vids? ive never heard one i dont think.
Jago, have you tried Putfile, rapidshare, google vids,etc?
you can put a screamer on an external gate cant you?
You could argue that you never drive on full boost on the street, so since the wastegate is always shut, then its not illegal at all???
if i were to install a screamer pipe... is it possible to install a bov?
just curious because of planning on buying one soon... but i thought that it wouldnt be no use since the screamer pipe already vents the gases from the wastegate??? that true???
ive always had a screamer on my car. with the factory turbo and with the new gt3540.
they obviously sound alot better on a bigger turbo with a ext gate.
but they still sound great on a factory turbo imho.
ill upload a few youtube vids for you to see.
who ever said they lost power putting a screamer pipe on is a bit weird. the idea of a screamer pipe is to releave back pressure which = better performance. how much is debatable. if your losing power get a retune.
a screamer pipe will only open wen the wastegate opens. on factory setups this can be quite random as they tend to open earlier when they are suppose to.
the theoretical process of a properly set up screamer pipe. will only open at FULL BOOST. if you have your car set to 2psi. it will open at 2psi. same as 10 or 20psi.
i have a 60mm ext gate and only opens at 15PSI. so i pretty much have total control of when i want to gate ppl.
to give u an idea of wat a car sounds like with a screamer/ext venting gate
i know alot of people are against these things, and i sorta feel bad for all the greenies out there wen i plant by foot. but in all honesty. nothing beats drowning out a V8 and pulling away leaving him to eat dust. on the track of course....................... :D
heres a story of how poo they really are, i had mine put on monday, spent 520 bucks on the whole set up, including modifying the front pipe to suit it, 3 days later, its coming off to make way for a one peice front/dump pipe costing me another 550 bucks.
dont get it mate, you will find it willl leak a hell of alot through the screamer itself, and sound like a tractor.
do it right the first time round and get a 3 inch turbo back :D
people who complain about a screamer pipe leaking hasnt got a properly made screamer pipe.
your suppose to separate the wastegate side from the exhaust side. that way when exhaust gasses pass through normally you dont get a leaking noise. and wen the gate opens. you get the scream.
honestly anyone out there who wants a properly made Screamer Pipe made for a factory Internally Gated set up PM me ill shoot u the guy who makes em.
they dont leak
they sound great
its highly illegal.
and unlike a few....i do have 1st hand experience
:O
it must be.. with retards replying to 2 year old threads..
oh wait.. you did that didn't you?
If youre not retarded and you could read you would see that it was 'Trouble' and not 'nizmonut' - they are actually 2 different forum names.
the fact that you can't understand how my comment was related to ANYONE who replied to posts from 2006 puts you down as the teamleader of the retard group.
congrats on the promotion Femno.
Just in case that didn't make sense to you, your husband "ALSO" replied to a post from 2006. he just decided that my amature comedy was to be pulled up.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
