  • Replies 82
Posted Images
i read threads on here about split dump pipes vs normal 3" dump pipes and it looks like the split pipes have a little more midrange,but the full 3" dump keeps pulling after 6500rpms unlike the split system.
From threads ive read on here^^^^^^^^^^^^^^^
ive been in a 32gtst with gt30r turbo + screamer pipe & it sounded awesome.
i've seen plenty of home made screamer pipes for stock turbos on here for sale and was told the gate only opens after your actuator has reached the stock psi limit (7psi i think) then the gate opens for the screamer pipe.
i myself have a full 3" dump and front from BATMBL
but wouldnt mind trying a screamer pipe after my turbo is hi-flowed.
conclusion: a screamer pipe for a stocker is like a BOV for a stocker.
IMO
My car when it had the Ext Gate.
http://users.tpg.com.au/nismohks/fullBOOST_mas_05_r31.avi
NOTE: I've never head an internally gated turbo sound even close to this.
So dont expect to get anywhere near what the video shows
cheers
cheers
aaah, memories
aquariuz6 - mate I have a 3.5 inch cat back system which needs a new muffler.
I'll sell it to you for $120.. a 3inch muffler will cost you about $200
say $50 for fitting
for $370, you will have a car that will sound great and actually improve performance.
a screamer pipe is higly illegal in NSW as it is sending exhaust gases out without going through cat.
In NSW, the fine for NOT having a cat (which is what a screamer pipe essentially is) is $10,000.
now.. you tell me. $370 for improved sound and performance? or $10K for nothing..
if i were to install a screamer pipe... is it possible to install a bov?
just curious because of planning on buying one soon... but i thought that it wouldnt be no use since the screamer pipe already vents the gases from the wastegate??? that true???
bov's and wastegates are seperate things althogether, a wastegate vents air away from the turbine wheel to prevent it from over boosting, and a bov will simply open when u back off to prevent the air going back through the compressor when the throttle is closed
i know the fines 10k for no cat but what is the fine for a screamer? i have mine set up with a flange so i can easily have it on or off coz i luv the sound but dont look forward to the fines even though it is very hard to see it, so yeh anyone know the exact fine for them
ben...
Edited by 2BNVS
Ok, you have things totally backwards as 2BNVS said..
www.howstuffworks.com
have a solid read there. If you are still not clear.
But to go and actually talk to a workshop mate as i feel you could be purchasing parts that you really dont need and wont benefit the performance of your car
doesnt a screamer pipe only loud when the wastegate opens?
so if i were to control my boost... not reving over 4,000 then that my wastegate shouldnt open.... or does it?
btw all new to this turbo side of cars...
also since i have a stock rb25det engine, what good would installing a bigger wastegate to my stock turbo do for me?
i think it wouldnt do me any good anyways because arent the stock turbo's ceramic and can only withstand 12psi max boost before causing any damages?
Guest
