The thing i always find it funny on here is people say, "its federal law, and its illegal" but how many people's car break the laws here, or break the laws in their cars.. i dont think anyone could say they dont.
Most of us obey the spirit of the law, even if they don't always manage to match the letter of the law.
Emissions laws are there to protect the environment - while its one thing to run the car a bit less fuel efficiently to chase more power so it produces more carbon dioxide, its something else entirely to dump poisonous chemicals directly into the air. Its even worse since its a street car, and so there are innocent people breathing in that shit.
  • Replies 82
Posted Images
yea i was planning on installing a bov onto my car...
the gfb bovus maximus but it seems that the ssqbov is pretty popular
once i install my 3" turboback exhaust i will plumback the screamer pipe
jus wanted to have some fun with some noise
Here is a video of [M SPEC]'s 33, with an internally gated HKS 2535.
http://s32.yousendit.com/d.aspx?id=2LCEAIW...V70PE2GEKSDPPW1
This link will expire in 7 days.
:P
No, that car does not have an Internally gated 2535 at all... please make sure you dont post misleading stuff about someone else's car.
The turbo at the time was modded to remove the int gate to run a bigger external gate.
The turbo has since died (at calder) and is being replaced with a 3037
You've never done a burnout thats made smoke for "innocent" people to breathe in before? Im not having a go at you, but if anyone gets a wiff of your gas after your external gate has opened, its hardly going to harm them..
  • 2 years later...
does anyone have any sound or video clips or screamer pipes?
i dunno bout screamer pipes but see if you like this, its 3 inch straight out the side. infront of the rear wheel.
http://au.youtube.com/watch?v=C4pm7OvTqco
awww.. so no vids? ive never heard one i dont think.
Jago, have you tried Putfile, rapidshare, google vids,etc?
you can put a screamer on an external gate cant you?
You could argue that you never drive on full boost on the street, so since the wastegate is always shut, then its not illegal at all???
if i were to install a screamer pipe... is it possible to install a bov?
just curious because of planning on buying one soon... but i thought that it wouldnt be no use since the screamer pipe already vents the gases from the wastegate??? that true???
ive always had a screamer on my car. with the factory turbo and with the new gt3540.
they obviously sound alot better on a bigger turbo with a ext gate.
but they still sound great on a factory turbo imho.
ill upload a few youtube vids for you to see.
who ever said they lost power putting a screamer pipe on is a bit weird. the idea of a screamer pipe is to releave back pressure which = better performance. how much is debatable. if your losing power get a retune.
a screamer pipe will only open wen the wastegate opens. on factory setups this can be quite random as they tend to open earlier when they are suppose to.
the theoretical process of a properly set up screamer pipe. will only open at FULL BOOST. if you have your car set to 2psi. it will open at 2psi. same as 10 or 20psi.
i have a 60mm ext gate and only opens at 15PSI. so i pretty much have total control of when i want to gate ppl.
to give u an idea of wat a car sounds like with a screamer/ext venting gate
i know alot of people are against these things, and i sorta feel bad for all the greenies out there wen i plant by foot. but in all honesty. nothing beats drowning out a V8 and pulling away leaving him to eat dust. on the track of course....................... :D
heres a story of how poo they really are, i had mine put on monday, spent 520 bucks on the whole set up, including modifying the front pipe to suit it, 3 days later, its coming off to make way for a one peice front/dump pipe costing me another 550 bucks.
dont get it mate, you will find it willl leak a hell of alot through the screamer itself, and sound like a tractor.
do it right the first time round and get a 3 inch turbo back :D
people who complain about a screamer pipe leaking hasnt got a properly made screamer pipe.
your suppose to separate the wastegate side from the exhaust side. that way when exhaust gasses pass through normally you dont get a leaking noise. and wen the gate opens. you get the scream.
honestly anyone out there who wants a properly made Screamer Pipe made for a factory Internally Gated set up PM me ill shoot u the guy who makes em.
they dont leak
they sound great
its highly illegal.
and unlike a few....i do have 1st hand experience
:O
it must be.. with retards replying to 2 year old threads..
oh wait.. you did that didn't you?
If youre not retarded and you could read you would see that it was 'Trouble' and not 'nizmonut' - they are actually 2 different forum names.
the fact that you can't understand how my comment was related to ANYONE who replied to posts from 2006 puts you down as the teamleader of the retard group.
congrats on the promotion Femno.
Just in case that didn't make sense to you, your husband "ALSO" replied to a post from 2006. he just decided that my amature comedy was to be pulled up.
Guest
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
