I know you are all (mostly) import fans here, but I found this video and thought it was pretty cool and interesting.
Its always good to know about the other cars (domestics) and we can all agree that Ford > Holden.
Anyway hope you all enjoy! >_<
F6 Tornado vs Super Pursuit
With that type of launch I wouldnt mind lining them up :D.......Aust jurnos are idiots.
V8 turbo = no Tornado can catch :laugh:
I wouldnt mind seeing the torque curve on those two. One thing going against the V8 is its a heavier beast.
Edited by monaroCountry
That video is a joke as they have no idea how to launch a car.
The new Auto Typhoon/Tornado has been clocked at 0-100km/h in 5.1 and the 1/4 in a 13.2 straight from the factory. If you plug a Ford Edit into it, expect a mid 12sec 1/4.
These cars are simply awsome with the new ZF 6 speed auto.
13.2, i dont think so. With 260kw and all that barge it would be in the high end of 13's with a good driver ..
the v8 has 290 and 520 going for it
while the i6t has 270 and 550 - the most torque ever for an ozzy built car
un freakin believable
wait till they come out with the territory turbo and then see if they adapt the drivetrain from that and put it in a sedan mmmmm 245kw i6t all wheel drive
interesting.....
however, i was concerned about the size of the wing mirrors on the ute. the whole time i was totally sh1tting myself, wondering if she could see what was happening behind her ;)
HAHA!
Edited by Frink
i have driven my sisters Typhoon on a number of times its a lot faster then my liner but doesn’t handle as good all wheel drive would b awesome. Cant wait to see some footage of the DRIF6 Typhoon
http://www.fullboost.com.au/news.php?newsI...ullBOOST%20news
  • 1 month later...
i hate the way aussie tv shows are so fkn cheesy about things.
they always have to cheese the shit up so the average wanker whos sitting around waiting for burkes backyard and getaway to start sit through it.
nice cars but, would never buy one though.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
