g'day every one. Vic drift are having a practice day at winton on the 11th of march. i figured a few of the sliders out there would be interested.
I’m proud to announce that VicDrift will be hosting a Drift Practice day on the 11th of March 2006 @ Winton Motor Raceway.
Details are as follows:
The Day Consists of a full day of Practice with a Top 16 battle at the end of the day.
Scrutineering would open at 8am.
Drivers Briefing @ 9 am.
Cars on track by 9:30 am.
VicDrift will have a number of mentors available for you to utilise on the day to assist you in improving your Drift Technique if you require. This will be espically good for first time drifters.
First time Drifters are encouraged to join us as the day has been designed to cater for begineers to expert drivers.
Practice all day with a small lunch break.
Then at 4:30pm we would start a TOP 16 battle for drivers that have been selected throughout the day by the judges.
Driver Entry fees will be: $130 for Members of Victorian Drift Club, and $160 for Non-Members.
Spectator Entry Fee: $15
We will have 2 Drift Vehicles Available for Spectator Passenger Runs on the Track, final costing for passenger runs to be advised
A AASA Licence will need to be purchased for the year @ $45, which will be needed for other tracks so it will be good to have.
There will be Tyre changing available: $15 per tyre changed, which includes disposal of old tyre.
More Details to follow!
for more info go to www.vicdrift.com
cheers, jonno
https://www.sau.com.au/forums/topic/108307-vic-drift-winton/
cheers, jonno
hey mate just a quick question, would you reccomend pulling front bumper off an r33 at winton for a first time drifter? done a few track days out there and can see my bumper gettin totaled!
cheers
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
