Driver Posted March 5, 2006 Share Posted March 5, 2006 Hey all, I used to have my ebc and turbo timer stuck ontop of each other and that was then stuck under near the steering wheel using double sided tape. 1 year later it came unstuck and ever since then i can never get any double sided tape to stick, ive always cleaned the surface before using new tape and no i dont want to drill any holes in my car. Anyone got any suggestions? Ta in advance Brendan Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/ Share on other sites More sharing options...
Bro'Duh Posted March 5, 2006 Share Posted March 5, 2006 Hrm try golo? Lol my friends got some, but his not picking up his phone atm if nobody has replied here ill get in touch with him a bit later. Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1996560 Share on other sites More sharing options...
Flux Posted March 5, 2006 Share Posted March 5, 2006 aisle 5 at bunnings, builders hardware Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1996563 Share on other sites More sharing options...
dangerous_daveo Posted March 5, 2006 Share Posted March 5, 2006 Or use heavy duty stick on velcro. It works pretty good. Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1996574 Share on other sites More sharing options...
Wink Posted March 5, 2006 Share Posted March 5, 2006 I vouch for hardcore velcro (as in the real velcro brand). Other than that the double sided tape that came with my GReddy EBC is pretty damn hardcore and shits all over the cheap tape. Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1996593 Share on other sites More sharing options...
croat Posted March 5, 2006 Share Posted March 5, 2006 i use velcro but the problem with all sticky things is thayt in the sun they melt down and fall off. Always a headache! Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997406 Share on other sites More sharing options...
gt-t_r34 Posted March 6, 2006 Share Posted March 6, 2006 i had to get double sided tape for my side skirt still havent found any thats holds!!! Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997620 Share on other sites More sharing options...
GTshortie Posted March 6, 2006 Share Posted March 6, 2006 i had to get double sided tape for my side skirt still havent found any thats holds!!! i use to have both my EBC and turbo timer stuck in the same position as you, tried velco & heap of double sided tape. THEN i got my beloved AVC-R so now its only the turbo timer sitting in that position, and guess what i'm using??.. haha its a bit dodgy i must admit but it works 'BLU-TAC' haha thats right and a heap of it!... still holds in the heat to my surprise. Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997742 Share on other sites More sharing options...
Bro'Duh Posted March 6, 2006 Share Posted March 6, 2006 Hrm duck tape? Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997832 Share on other sites More sharing options...
Suspense Posted March 6, 2006 Share Posted March 6, 2006 bunnings bro Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997876 Share on other sites More sharing options...
SirSkyline Posted March 6, 2006 Share Posted March 6, 2006 I used 3M VHB double sided tape but you have to wipe wax and grease on the area first it will fall off. You should wipe wax and grease over it no matter what you use, because the plastic is oily and nothing will stick to some thing thats oily. Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997896 Share on other sites More sharing options...
Chris32 Posted March 6, 2006 Share Posted March 6, 2006 We use this shuff at work called 'Husky' double sided tape. It sticks as good as anything I have ever seen. You should be able to get it at a arts supplies store or something like that Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1997986 Share on other sites More sharing options...
GM_GTR Posted March 6, 2006 Share Posted March 6, 2006 Hi Driver, I had exactly the same problem.. both my ebc and turbotimer are together so whatever I used it would just fall off whenever it got too hot, anyway the one I found that has worked is from supercheap autos, there's a greenish double sided tape that comes in a roll(no kidding ) You just need to lay strips of it on your tt or ebc and it won't fall off.. there's another roll where the foam is a bit thicker, its black I think(don't get that one), look for the thinner one.. it's only about 1-2mm think and about 5mm wide... I've had it on for over a year and it's still really tight even when I push on it.. good luck Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-1998039 Share on other sites More sharing options...
lang Posted March 7, 2006 Share Posted March 7, 2006 i dont know the brand of the tape but.. my r32 gtr had an oem nissan dealer fitted knee brace/pad on the drivers door and center console. they were fkn annoying so i tried to remove them. the double sided tape they used on these was f**king hardcore, in the end i had to take the door skin off and use a filleting knife to cut between the door skin and the knee brace thru the foamy part of the tape, could not get it off any other way, im still stuck with the glue on the door trim, cant get it off. so if you really really want to fix it will this stuff exists, goodluck ever gettting it off tho Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-2000667 Share on other sites More sharing options...
choicom Posted March 7, 2006 Share Posted March 7, 2006 I use this black 'blu-tak' lookign thing i found in the garage. Works on all interior parts Used it for the boost gauge, attaching the speaker xover under the dash, and tweeters to the dash also. i think it is in bunnings? Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-2001709 Share on other sites More sharing options...
funkymonkey Posted March 7, 2006 Share Posted March 7, 2006 aisle 5 at bunnings, builders hardware lol pick the bunning employee Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-2001793 Share on other sites More sharing options...
CruiseLiner Posted March 8, 2006 Share Posted March 8, 2006 sikaflex but dont expect to remove it without alot of struggle Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-2004425 Share on other sites More sharing options...
Savage Bliss Posted March 8, 2006 Share Posted March 8, 2006 Yep, try hardware stores. I got some from my local dude to do the same thing. 18 months later and two summers, no timer/control unit lying on floor. Just ask for the heavy duty shit! Link to comment https://www.sau.com.au/forums/topic/108330-hardcore-double-sided-tape/#findComment-2004846 Share on other sites More sharing options...
