sl33ek Posted March 5, 2006 Share Posted March 5, 2006 Hi guys My alarm is farked so I'll be driving around without an alarm for next few weeks until I can put one in I might be parking in some dodgey places and thought about removing a fuse in the mean time after I park the car. Question is which fuse is the best to pull out and where is it? I prefer removing a blade fuse and not the type that is in its own box because its easier to carry around and keep spare blade fuses Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/ Share on other sites More sharing options...
Links Posted March 5, 2006 Share Posted March 5, 2006 I think you can pull the Airflow meter cable out.. car won't start as it needs it working.. but double check, someone else should know.. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-1997339 Share on other sites More sharing options...
FOG35 Posted March 6, 2006 Share Posted March 6, 2006 Many fuses can be pulled out to disable car. Fuel pump, starter, ign etc. The one i used before i had an alarm installed was the ignition fuse from the fuse box in the engine bay. A good idea when you decide which fuse to pull would be to replace the fuse you pull with a blown fuse. That way it is not obvious to the theif which fuse to replace. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-1997500 Share on other sites More sharing options...
blind_elk Posted March 6, 2006 Share Posted March 6, 2006 My experience has generally been that they don't want the car, they only want what's in it. Having an alarm didn't prevent them sitting inside and stealing the radio; so now I have installed one of those Jayco Screecher alarms (110dB @ 2kHz) - it certainly reminds them that they haven't been invited into the car. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-1997532 Share on other sites More sharing options...
RANDY Posted March 6, 2006 Share Posted March 6, 2006 Pulling a fuse is probably easier than disconnecting the AFM... and pulling the ignition or starter would give the same result as an immobiliser... so I figure most theives would assume that there is an immobiliser and just go to town ripping anything out of the car that they can. Might want to wire up a flashing LED or something in the meanwhile. I feel much more comfortable knowing that my alarm has a flashing LED. Kinda deters theives from even bothering in the first place I guess. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-1998110 Share on other sites More sharing options...
RANDY Posted March 6, 2006 Share Posted March 6, 2006 What about one of those power inverters that give you 240v out of a 12v source? Rig that up to parts of the car that are metal but not grounded... Might be better suited for electifying your wipers. No more parking tickets! ;o) (jk people... don't do this) Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-1998113 Share on other sites More sharing options...
sl33ek Posted March 6, 2006 Author Share Posted March 6, 2006 ^^ lol. if i did that I'd more likely toast myself than a thief. I'll go with arh32, i have a burnt fuse I'll use to swap with my fuel pump fuse in the mean time, i think thats a great idea. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-1998219 Share on other sites More sharing options...
SECURITY Posted March 7, 2006 Share Posted March 7, 2006 or hook up a switch to it? im hooking up a kill switch on my car. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2000752 Share on other sites More sharing options...
blind_elk Posted March 7, 2006 Share Posted March 7, 2006 I'll go with arh32, i have a burnt fuse I'll use to swap with my fuel pump fuse in the mean time, i think thats a great idea.So good that now every bloody car thief who frequents these forums knows to carry around a spare fuse as the first remedy to pinch a car that won't start. (which is why I have never publicly announced my secret anti-theft weapon).I feel much more comfortable knowing that my alarm has a flashing LED. Kinda deters theives from even bothering in the first place I guess.You obviously didn't read my previous post - thieves could care less about flashing red LEDs. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2000775 Share on other sites More sharing options...
Guest Xinhua Posted March 7, 2006 Share Posted March 7, 2006 or hook up a switch to it? im hooking up a kill switch on my car. Thats what i did for my car mate.. theres a switch under my floorpanel.. very hidden.. can't start the car without pushing the switch.. you can put the key in and turn.. nothing will happen.. Works very well.. good luck Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2000974 Share on other sites More sharing options...
SECURITY Posted March 7, 2006 Share Posted March 7, 2006 Thats what i did for my car mate.. theres a switch under my floorpanel.. very hidden.. can't start the car without pushing the switch.. you can put the key in and turn.. nothing will happen.. Works very well.. good luck probably the best example ive seen of someone asking to get their car stolen. saying youve got a kill switch - ok. giving the exact location.... that shits just not smart dude. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2000995 Share on other sites More sharing options...
Guest Xinhua Posted March 7, 2006 Share Posted March 7, 2006 no one knows what my car looks like.. hence where i live.. giving fellow sau members an idea.. also it will be changed tonight.. guess i shouldn't of told anyone.. no big fuss eh Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2001040 Share on other sites More sharing options...
JimX Posted March 7, 2006 Share Posted March 7, 2006 I think it's good to flood the topic with information. The more people that give ideas, the more variety people can use, and any thief reading through will have to remember 20 different places for 50 different cars. He's not going to go through each and every one to find the "trick" to stealing it. On the other hand if we only heard about the blown fuse one, anyone without an alarm and without any better ideas would probably do it, and the thief would be able to casually check every car for blown fuses and probably get a couple easily. It's probably best to use a combination of things. For example, pull a fuse as well as putting a kill switch in, or 2 kill switches in different areas. I've got 3 different things - club lock, alarm with starter kill, a separate 3 point immobiliser, and a kill switch. Sure you can always tow it but if the thief is determined nothing will stop him. The best defence I've found though is to not park it in dodgy areas. Also a good idea for the kill switch is to not necessarily have it as one of those metal toggle switches. Something that doesn't seem like a switch to the touch, like a you press. A friend has a "toggle" button which you can push up or down for on/off. If you were feeling around without knowing about it you probably wouldn't even notice it, it would feel like one of those plastic screws you use for keeping the kick panel on. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2001148 Share on other sites More sharing options...
paulr33 Posted March 8, 2006 Share Posted March 8, 2006 you can also unplug the crank angle sensor at the front of the engine it wont start with it unplugged Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2002713 Share on other sites More sharing options...
Beer Baron Posted March 8, 2006 Share Posted March 8, 2006 a car i've driven before had a good idea. it was some kind of circuit linked to the starter. you had to complete the circuit to use the starter. you had to be touching the key with your right hand, and with your left reach down to a screw that holds on the left kick panel (side of center console) this would complete the circuit and allow you to start the car. quite a good one. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2002847 Share on other sites More sharing options...
Guest Xinhua Posted March 8, 2006 Share Posted March 8, 2006 so the point of these kill switches is so they can't hot wire it am i right? what if they just tow it? theres no defence on that at all? lift the back wheels and tow it right out of there Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2003423 Share on other sites More sharing options...
FATGTS-R Posted March 9, 2006 Share Posted March 9, 2006 Well yes it can be towed. But opportunistic car thives dont have tow trucks at disposal. As mentioned, if they really want your car they will get it. A lot of my friends have kill switches and they are in some ingenius places, well hidden places and right in front of you places. Like using one of the factories blank switches and putting a switch there as the kill switch with "demister" for example. Multiple horn button steering wheels with one of the buttons used to complete the starter circuit. Another mate has a buggered electric aerial and you have to press the aerial up button to start. But to reiterate what I said it can still go missing. Mechanics are a good place where your guard is let down. You might of been there for 10 years and trust the guy with your life but his apprentice who started a week ago might need to move the car and ask "how do I start this thing". Then cut your key during his lunch break and....you get the idea. Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2007315 Share on other sites More sharing options...
ross80 Posted March 13, 2006 Share Posted March 13, 2006 great genquis! Where do you park your car because now i know how to knock it off ! lol YOu idiot! Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2014845 Share on other sites More sharing options...
ross80 Posted March 13, 2006 Share Posted March 13, 2006 Hey since you guys are tellling everyone your secrets about wiring and fuses now we have to do all of them at once so they cant guess which one it is! Or take the engine out with a crane and put it in our lunch box you morons! Shut the f**k up and youse your brains! Not everyone on these sites regardless if they own a skyline is trustwrthy! I knew of a guy with a vl turbo with a rb25det and everyone of the performance parts he had on the car were ripped off other cars! f**ks sake Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2014864 Share on other sites More sharing options...
sl33ek Posted March 13, 2006 Author Share Posted March 13, 2006 LoL sorry. I didnt ask for any secrets I actually pulled the fuel pump fuse out a few times in the past week and put a blown one in when going out, the peace of mind was more than worh it. I cant watch a movie knowing the car is not secured. I got a very decent alarm installed on Sunday, I wont say what it is! Link to comment https://www.sau.com.au/forums/topic/108343-removing-fuse-to-disable-car/#findComment-2015094 Share on other sites More sharing options...
