how much for just a front pair, if u sell them in a front pair that is....
also how much for a pair of front springs? at 7kg rate
cheers
Hi mate, they are only available as a set of 4 im afraid.
Regards,
Steve
hey just jap,
I have a set of TEINS ,, just wondering if these coiovers will be a softer ride?
Also, to everyone else im just wondering if any of you have bought a pair of these and are you happy with your purchase?
Cheers,
-JD
hey just jap,
Cheers,
-JD
Hi JD, there is some feedback from one of our customers earlier in this thread.
As for the ride, we can provide the shocks with a spring rate package suited to your specifications
The ride in standard form is quite forgiving on the street, if you purchase a set and find them a little stiff, we are only to happy to switch the springs for some lower rate items for you.
Cheers,
Steve
Thanks for all the orders guys, this special of $1399 will end shortly so get in quickly to take advantage of this fantastic offer.
Cheers,
Steve
so i cant just buy a pair of front springs? or front coilovers?
Sorry, we sell G4 coilovers as a set of 4 only.
If you are after springs themselves, please contact us on (02) 9545 0532 and we may be able to assist you.
Regards,
Steve
Thank you to all of you who have already purchased your set of G4 coilovers at this special forum member price.
This offer will end shortly so get your orders in now to avoid missing out on this fantastic deal from Just Jap
Purchase your set online now via our website using the URL below:
http://www.justjap.com/forumg4special.htm
Cheers,
Steve Thatcher
Just Jap
when does this offer end? and does r33 gtst set have front pillow ball tops? thanks
Hi mate, this offer will be valid for a little while longer.
Skyline kits do not come with pillow ball tops
Regards,
Steve :)
Do they make them for a 91 Aus delivered LS400?
Hi mate, we have them listed for 94-00 LS 400 only.
Regards,
Steve
  • 1 month later...
The first post has been updated.
Just Jap is now offering G4 Coilovers to SAU members for $1399 delivered Australia wide - Offer strictly limited so get in quick to secure your set!
Regards,
Steve
  • 2 months later...
Hi guys, thanks for all your support.
We are still offering these coilover suspension kits at $1399 delivered and we have around 200 sets in stock now for all popular makes and models.
Each kit includes a full 12 month replacement warranty and we have a range of different rate springs in stock all the time allowing you to fully customize your G4 suspension package to suit your application.
Cheers,
Steve
  • 1 month later...
I've enquired about your brake setup in the other thread
but i forgot to ask, do you's combine postage to make it a bit cheaper if i purchase the front n rear brakes + suspension (for a R32 GTST)
Thanks
Hi, A couple of Quick q's
I can't find the entry for R32 GTS-4, or is it just as good to use the GTR ones?
Also, do you have a preferred installer in Melbourne?
Hi mate, we have specific kits in stock to suit R32 GTS-4.
In terms of installation, we dont have a preferred installer as such in Melbourne, but installation really is very very simple so any reputable workshop should be able to handle this for you.
Cheers,
Steve
  • 1 month later...
Another large shipment has just arrived so we have hundreds of sets of G4 in stock now ready to go.
We also have a large selection of different rate springs in stock, allowing you to effectively choose your desired spring rates before you order and we offer a free spring change over service to our customers.
Thanks for the support guys.
Steve
  • 1 month later...
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
