Hey everyone,
Can anyone recommend a trusted performance work shop that does pre-purchase inspections on japanese performance cars?
Possibbly in SE melbourne area.
Thanks
Good question. I got RACV to do the full test on Line im looking at... the works with hosting the car up etc. *Fingers crossed*
Im actually going to look at a car this week aswell and i was thnkin the exact same thing... where can i get a full inspection of the car done??????
where did you go for that?
do they have a workshop you can take it to??
how much is this going to set you back??
anyway hope it all goes well for you, goodluck with the car :laugh:
if anyone else knows of a place i'm sure we'd all like to know about it
i just went through this, it's a pain in the but. i used racv, the only thing is they wouldnt come out to see it, cos its an import or something, anyways they'll only do a comprehensive check, set me back $215. it can get expensive if they dont pass, the first one i got checked out didnt. if its a black series 2 in the malvern area pm me lol
anyway hope it all goes well for you, goodluck with the car :/
Well I booked it so they are doing it tomorrow, then fax the details the next day.
I rang via their direct number and got connected to the department. The car is in Dandenong so they the nearest RACV place is at Cheltenham... the car yard guy has agreed to drive it there on Wednesday... although the car is not complianced yet.
Im an RACV member so it cost me 215... but they should do a major test... host it up etc, for non mbers its closer to 280.
Ill let you know at the end of the week how it all goes.
Edited by Sir-D
what car yard? power rd? the guys at cheltnam did 2 tests for me, they check everything, even picked up some body repairs that i couldnt see.... plus they'll pick things you might not notice in a test drive
i actually went out to pick up the report, that way the guy that did it can discuss it with you and point things out...
good luck...
Edited by morgsj50
My old man once bought a car after having it "RACV inspected" and they missed a whole heap of stuff and the car ended up being a lemon. Better to take u car to an import specialist. Theres quite a few in the SE region, kangaroo rd oakleigh is one but there are others that i can remember off the top of my head.
I had Nizpro do the pre purchase inspection on my car.
Cost was $250 and included a road test, full mechanical and suspension/brake inspection. Body/chassis inspection.
Leak down and compression test along with a power and air/fuel ratio test on the dyno.
I thought it was expensive at the time but after seeing that RACV want over $200 to scratch there heads I guess its a bargain.
Do RACV do a leak down?
I was unable to get my friend mechanic to look at it as he has a workshop in Brunswick but the car is in Dandenong. But after RACV check the car and if they OK it, ill take the car to him and do another inspection to confirm what they said... if anything is dodgy its back to the car yard to fix the problems or money back.
Edited by Sir-D
Thats it, also make sure u do a leak down test, prb the most important one
Well the report came today... there is a need to catalytic converter to be changed (i think its cos of Australian compliance) also the engine has oil leaks which needs immidiate attention according to RACV. I told the car yard and they are meant to fix it up this and next week. I told them unles they fix it Im not getting it. Shoukd I bargain on the price now since theres a few things wrong with it? Also it drifts slightly to the left when driving so wheel balance is needed.
Leak down test is to see what leaks like the oil??
i'd be careful, the car yard is gonna fix it as cheap as they possibly can... depending on what else is wrong, i'd probably be lookin else where, but, at the end of the day it's your money...
Yeah I will have to get it rechecked by RACV again, its like 75 bucks. Also the car has 12 month warranty as long as you service every 6 K and no engine mods.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
