ive rung a few places so far, justjap, uas, and nissan. nissan want 500+ for a standard rb25det oil pump and justjap and uas dont stock the standard pumps.
if worse comes to worse ill be getting an n1 pump from justjap for 499 but does anyone know anywhere else that would have standard rb25det oil pumps?
https://www.sau.com.au/forums/topic/108412-where-do-i-go-to-get-an-oil-pump/
Yeah go new, heres a link to the club discount guy
http://www.skylinesaustralia.com/forums/in...ndpost&p=974243
Powerplay did a oem airbox for a good price for me ages ago, give them a try maybe?
Steve: Troy at Nissan has left, and the new guys are useless
SECURITY: I really think you need to be sure about what you are dealing with before you go buying a new oil pump unless you are certain that your current pump has a problem, especially since you are obviously doing this on a shoestring budget.
Lift the engine out, and strip and reassemble it properly - without using assembly lube on the bores!
we're going to pull the oil pump off and have a look at it, if it seems ok then we're going to look at the clearances of the rod bearings.
but we put in new standard bearings, and the old bearings were standard so the only thing left would be the oil pump.
whats happening is its running, except ive got what sounds like a lifter noise. just a clicking in the head, but that could be caused by the thinner oil and a dodgy oil pump.
oil pressure rises to 30+ psi when its at around 3000rpm, so its got me stumped!
it was done right, just because we didnt have a workshop doesnt mean it was done wrong. and to the best of my knowledge the oil pump was fine so we didnt think of changing it.
it isnt a big problem. its either the big ends or oil pump. ill be changing both while the sump is off anyway. bearings cost me $60 so it isnt a big deal to change them to be on the safe side. im buying an n1 oil pump this thursday so it'll all be fixed over the weekend.
Mate you don't understand its got nothing to do with having a workshop. Take the engine out of the car, take the crank out and have it checked by someone that knows and has the tools to do it .You say you checked the bearing clearances , how can you do it on the car ? By using new bearings again its not going to make any difference if they are the same size as before .
You must have done something wrong otherwise she would be fine. If i was you i would check the piston to bore clearance too , it has nothing to do with oil pressure but it may have something to do with the clicking sound ( piston slap if the clearance is to big ) . You should also service the cil head while you are at it, saves you having to pull it off in the very near future .
im just going to leave it to my brother in law. hes confident he knows what the problem is, its too much of a damn headache for me.
thanks wrxhoon, hope you dont mind if i pm you another time if ive got any problems mate. cheers.
security I understand you are trying to do this cheap but I guess the point is you've done a commodore style rebuild on a skyline :D
I'm sure you want car that you can take back to the strip and trhash when you are finished, for god sake don't cut corners and end up with a problem a third time.
Take the motor out
Get the bottom end cleaned and tested and honed properly
Deck the block
Then have the bearing, piston and ring clearances checked.
Buy a new oil pump.
Get the crank measured for straightness.
Get it all balanced.
Get new rod bolts.
Get the right size bearings.
Check the ring end gaps to make sure they are right.
Make sure you have the right grade pistons for your current piston clearances.
Clean the bottom end out properly instead of leaving the shavings from the honing floating around in the block.
Shave the head
Get the head pressure tested
Yes I would know I've done it cheap and wrong myself.
Or failing that do what I did and install a second hand motor. The fact is you did hge damage with that melted piston but never cleaned the block out....
Good luck with it all ;)
I'm with Duncan & WRXHOON. Take it out and do it properly or you're pissing money into the wind. It's just going to break the way you've built it now there's been too many corners cut. You CANNOT build an engine properly, especially a high performance once, without taking it out of the car.
If you're not going to listen to the answers don't bother asking the questions, we're only going to tell you "I told you so" afterwards.
Good luck getting it sorted anyhow but for your own sake please take the engine out and build it properly.
Edited by d0p3y
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
