I am selling my work of art, s13 silvia sleeper which has been totally engineered and is really a good buy for what u get ,so yes it is a long read, but if you are serious then it is worth wild. he wants 30 K..
VEHICLE:
Make NISSAN Model SILVIA Year 1991
Reason for choosing this car PERFECT ROAD CAR, DRIFT CAR, RACE CAR
Background of car WAS DEDICATED DRIFT CAR THEN IT WANTED TO HIT THE STREETS
PERFORMANCE:
Power 680HP @8000 rpm
Torque 1080Nm @6800 rpm
Measured at wheels or engine?ENGINE
Do you have a printout of the dyno reading.........Yes
1/4 mile 12.6 sec 117 mph
Do you have a time card.........Yes
0-150 km/h 7.2 sec
ENGINE:
Make NISSAN Model RB26DETT Year 1993 Cylinders 6
Standard capacity 2600 Current capacity 2700 Comp ratio 8.3/1
Cylinder Block
Crack tested....Yes Pressure tested....Yes Bored.....No
Crankshaft
If not standard, Type TOMEI Stroked....Yes Crack tested...Yes Cross drilled....No Ground....No Balanced...Yes
Con rods
If not standard, Type TOMEI Balanced.....Yes
Pistons -
If not standard, Type TOMEI Balanced...Yes Rings MOLY GAPLESS
Cylinder Head(s)
Alloy or cast iron? ALLOY Porting work.....Yes
Combustion chambers modified.....Yes
Chambers ccíd.....Yes/No Type of valve springs and retainers TOMEI 10,000 RPM Guides TOMEI
O ringed..... No
Camshaft(s)
If not stock, Type TOMEI
Specifications 260 DEGREE INTAKE AND 260 DEGREE EXHAUST DURATION WITH 9.15mm LIFT
Induction
Turbo or Supercharged? TURBO Standard...No (If no, what type is it? TRUST TD05-22G X2)
Boost pressure 24PSI
Boost controller type BLEED Wastegate type TRUST Intercooler GTR
Inlet manifold (if not stock) STOCK Air filter type HKS
Other mods to induction 3” CUSTOM INTERCOOLER PIPING
Fuel injection
Management system (factory, Motec, Wolf etc) MINES REMAPPED STANDARD
If factory, does computer have standard, remapped or aftermarket chip
Fuel pump type WALBRO 1000HP Injectors 700CC
Fuel type BP ULTIMATE
Standard fuel tank...Yes
Other changes to injection system SARD FUEL PRESSURE REGULATOR
Ignition system
If not stock, describe any changes SMALLER GAPPED IRIDIUM SPARK PLUGS
Exhaust
Changes to stock
System TRUST HIGH MOUNT MANIFOLD, TRUST WASTEGATE DUAL 2.5” MANDREL DUMP PIPES INTO 3” EXHAUST BEFORE HIGH FLOW CAT THEN INTO 3” MANDREL BENT EXHAUST TO REAR MUFFLER.
DRIVELINE:
Clutch -
Type OS GIKEN TWIN PLATE
Transmission -
Type...……..manual Number of gears 5
Any Mods RACE GEAR SET IN RB25DET GEARBOX
Shifter type SHORT B&M
Differential -
Ratio 4.375 LSD....Yes (If yes, type NISMO 10 PLATE 2 WAY LSD)
Other mods to differential and axles/driveshafts FULL GTR REAR CRADLE
BRAKES:
Front
Pads ENDLESS
Calipers and discs (if not standard) GTR
Rear
Pads ENDLESS
Master cylinder type if not standard GTR
SUSPENSION:
Front
Springs TEIN Shock absorbers TEIN
Strut brace ALLOYBushes BALLJOINTED TEIN
Rear
WHEELS AND TYRES:
Front -
Wheels type and size (Front) ENKEI 16 X 7(Rear) ENKEI 16 X 7
Tyre type and size (Front) GOODYEAR 225 X 50 X R16 (Rear) GOODYEAR 225 X 50 X R16
INTERIOR:
Describe all modifications and additions to the inside of the car, including gauges, controls, sound system, seats, etc.
R33 GTR SEATS, 180SX DASH, DOOR TRIMS, CARPET, CENTRE CONSOLE, BOOST GAUGE.
BODY:
Describe all modifications and additions to the body of the car including body kits, panel work and paint.
CUSTOM BURGANDY RESPRAY IN AND OUT. NATURALLY ASPIRATED FRONT BAR. (NO INTERCOOLER VENT).
ph 0401 729 440
FOR SALE $30,000
post-27143-1141630314.jpgpost-27143-1141630347.jpgpost-27143-1141630391.jpgpost-27143-1141630412.jpgpost-27143-1141630436.jpgpost-27143-1141630494.jpgpost-27143-1141630533.jpg
Edited by 180SXJET
https://www.sau.com.au/forums/topic/108440-silvia-rb26dett-engineered-for-sale/
  • 1 month later...
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
