Act Rego Passing
The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back -
So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
By r33.antwone · Posted
that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor -
By Toilet Goblin · Posted
ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
