any skyline gtst r33 for sale????
buy one from perth!
wat if u dun like the feel of the one from melbourne?
after u already brought it here?
then u would have to either sell it or send it back?
i doubt the owners would take it back anyways!
i heard extreme machines are quite good
adrian :)
Originally posted by trUnkz
hey im deciding to buy a skyline gtst r33...any1 know where i can find one thats in perth???? but if im planning to get it in melb...how much would it cost to import from melb to perth????
Mine is forsale ..
http://home.iprimus.com.au/r_huynh/skyline.html
trUnkz,
Do you want the car to be 'done up' to go quicker or 'done up' to look quick.
Looks are easy. Just buy the one you think looks the best.
If you want the car to go quicker, it is possible the car can be 'done up' the wrong way and you will spend the greater part of your income fixing it back up.
Here are a few tips:
As a part of the mechanical inspection, test the compression both hot and cold. Ask when the last time diff/gearbox and engine oils were changed etc and the regularity.
If the owner claims to have a car that does the 1/4 in any particular time ask to see the time slip. If the owner claims any particular power output ask to see the dyno printout and then totally disregard it.
Check the underside for any evidence of accident damage (Dents in the chassis rail etc. particluar attention to the front and rear).
The most important tip is to test drive as many skylines as possible including dead stock ones so you get a 'feel' for the car and the way it ought to behave.
theres a series 2 gtst with ohlins coilovers,cusco front/rear strut,fujitsubo exhaust,and unisia jecs pod filter. done 64000 ks.but will only be complied in 2/3 weeks. thats the only reason i didnt take it. asking for 26,000. and its at extreme machines
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
