Near new,
Has small scrath on top.
Your music in your phone — W800i Walkman®
Have your music with you wherever you are. Just press the music button to start your in-phone music player, select your favourite song or playlist and enjoy. Getting your music into your mobile is easy – the W800i comes with music transfer software. Move the music from your CDs. Fast and easy. And, to introduce you to the Sony Ericsson Walkman® phone experience, there are six top music hits waiting for you in your W800i.
Easy imaging
The W800i is also a 2 megapixel digital camera with video recording capability. Save your images in the W800i image gallery or move them to a PC. Let your friends see what you see using picture and video messaging (MMS) phone-to-phone.
Store more
The W800i has plenty of memory inside for storing your favourite songs, images and video. And when you need to store more, use Memory Stick™ PRO Duo. In addition to the phone’s internal memory, you can have up to 1GB expandable memory. Thousands of images. Hundreds of songs. The supplied 512MB Memory Stick™ PRO Duo gives capacity for around 150 music tracks - or 10-15 full length CDs.
Enhance with accessories
A quality headset is included in the phone kit. To enhance your sound experience even further, connect your W800i to your stereo with the Music Cable MMC-60. Keep listening but never miss a call. Your music automatically stops when a call comes in.
Designed for use
The W800i never compromises on ease-of-use. Synchronise and transfer files rapidly with the Fast port connector. Go wireless - connect to other devices with Bluetooth™. Share with friends and family in seconds with QuickShare™.
Firmware has been upgraded to latest version.
Includes box, headset, data cable 512Mb mem stick duo and charger.
regretful sale
https://www.sau.com.au/forums/topic/108542-sony-ericcson-w800i/
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
