G'day guys, I'm looking for a quick sale on my gtr as ive found another car i want to buy so i have to sell this to fund it.
White '89 32 GTR
Very very clean car in excelent condition.
White nismo gauges
Nismo 320kmph dash
Just run in from new rebuild
New daikin heavy duty clutch
2 week old 18x9.5s with 255 rubber all round
Apexi power FC
3.5" exhaust from tuebos back
Pod filters
Nismo adjustable fuel reg
GReddy turbo timer
Blitz Electronic boost control (mounted but not connected)
89,000 kays on the car
It is a really nice, clean example of a 32 gtr.
Hasnt been boosted since rebuild or revved over 6k because its only just ran in.
For a quick sale I'm after $22,000 ono as i need the money to buy the other car before it sells.
any questions/enquieries dont hesitate to call
0424583250
Cheers
Brad
Edited by nugget400hp
https://www.sau.com.au/forums/topic/108555-r32-gtr/
it made 308rwhp (around 230rwkw) on 12psi with a mines computer just before it cracked a ring.
Should go 250kw at the rears with the new computer and bottom end
https://www.sau.com.au/forums/topic/108555-r32-gtr/#findComment-1999795
