Item: R32 Gts-t 1992
Reason For Sale : Buying house
Item Condition: Very good
Price and Payment Conditions: 18k neg (will consider cheap ute trade, around 3k)
Extra Info: Car has a brand new set of Tein adjustable damper coilovers, Rear adjustable whiteline sway bar, front and rear strut braces, gearbox has been replaced, exedy H/D clutch, 3" exhaust from turbo back with highflow cat and stainless muffler, Splitfire Ignition Coils (6months old), Splitfire spark plugs, Brand new battery, K&N pod filter, Front mounted intercooler with S/S piping, replaced stock turbo with rb25 turbo, Greddy oil catch can, GTR LSD and Rear brakes, Bendix Ultimate brake pads, turbo timer, New sony head unit, Custom purple paint job with pearl, Full Veilside Bodykit (minus rear left pod, fell off because of loose screw), 18" 5 spoke chrome rims with brand new tyres, no spoiler, dark tint, a/m steering wheel, mint interior, debadged.
Engine is in prime condition, was replaced before I bought it and has only 80 000k's on it, all bushings in the suspension have been checked and the ones that were worn replaced with nylon bushes from fulcrum. All fluids and filters new. Basically everything on the car has been reconditioned or replaced.
Pictures:
For pics go to - R32 Pics
Contact Details:
[contact details recorded and removed by admin at OP's request]
https://www.sau.com.au/forums/topic/108577-r32-gts-t-drift-spec-for-sale/
