Hey guys i have the above rims available for a quick sale.
There 18s impul very popular rims in chrome they retail for about $2000
But these have a little gutter rash on two rims but can easily be cleaned up therefore im selling them cheaper.
I will take any offer above $1200 will post at buyers expense.
These fit skylines, s14/15 etc
http://www.tempetyres.com.au/products_clos...rt=&part_no=283
My camera isnt workin so the link is to the tempe tyres website where these rims are available i will try to get piks up of the gutter rash soon but if in sydney feel free to come see them. Tryin to get rid of the, before Friday.
Thanx guys any more questions jst Pm me
NEW ALPINE PRODUCTS
Type S 6x9 150ono
mrd-1005 amp 950ono
These are in absolutly great condition
Edited by bdazzld
https://www.sau.com.au/forums/topic/108589-1885-starcorp-racing-impul-chrome/
Ooooo...so tempting.....good price.........so pretty with skylines, yet so common, but still so pretty and so pretty.....................oh well....free bump
i really havent got pics of the rims but there exactly like the pic shows,
I also just double checked the width and they are 8.5" fronts and 9.5" rears so dnt no how the fit on R32 but im sure someone here will know!
As for postage i sent 17" rims to Vic for 100bux jst the other day so it shouldnt be much more than that
to see what these look like have a look on the third page of the photography pics of my car forum
my car is in there its silver 32 gts-t with these wheels
(not these actual wheels but same type)
  • 4 weeks later...
hey guys these are still for sale
stil on the car therefore some tread has been lost 3 tyres have little amounts of tread and would preferbly need replacing but i have already replaced one of the rears
therefore now selling for $950 ono
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
