Hi huys for now we are going with a T88 kit which we purchased from doughboy, off this forum.
Again anyone how has delt with chris will know that he has to be one of the best peopl eto deal with when buying car parts.
Thanks again Chris.
anyway
we purchased a T88-33D kit with a Sard wastegate.
We are just getting the kit cleaned and, sandblasted and then ceramic coated.
I'll get some photos up once the kit is put back together all nice and clean.
I thinkthis will be a good test to see what the results are like compared to GT-SS turbos to the T88.
Cheers
https://www.sau.com.au/forums/topic/108613-t88-time-on-our-gtr/
good luck with it, just wondering y the extreme change from the most streetable turbos on the market to the most laggiest of the lot? more power i guess? :) surely u aint gonna be using the t88 to its potential so y not something b/b and abit smaller, or isnt lag an issue?
cheers
Brad
cheers
Brad
I'd say with their motor combination they'll probably hit the limit of the turbo, and it will be a good showcase for Hypertune's range of products. I suppose their goals might be a bit more realistic than, say hypothetically, stuffing a big dollar race quality motor into an 1800kg grocery getter? Don't Coles carparks have a 15km/h speed limit? :)
maybe cause i want something different, not just another gtr. i want to park it up with people not knowing its fast, which cant be said for any model skylines and people automatically think they are fast, hence more getting stolen, or damaged from jeleous morons.
the motor wont always be in the stagea anyway, as it come out of a vl calais b4, and 2wd is just a waste of time, and r32 gtrs r too old with things looking dated (interior wise) and i dont like 33's at all, and 34's r mad but way too pricey.
i wasnt personally having a dig at 600hp's setup, i only asked the question as to why he went sooo big that was all? its pretty lame that u get shit from just asking a simple question, isnt that the point of the forums?
are we all supposed to just say thats awesome, and never find out y he is actually choosing it?
I agree with you cruiseliner... but you take the good with the bad. Although quite opinionated, this forum would have the most open minded (and knowledgable) people that i've seen on any forum... and thats why i think its one of the best. Bring up something like what BOV sounds the best and its a different story tho :)
Sorry for the slow reply.
the reason we went with the T88 is because we were maxing out the GT-SS we believe, and our engine was built for 800hp.
with the T88 onboard we will rev the engine up to 9500rpm were as now its only 8500rpm.
The 33d is the smallest so, with our engine combo it might not be as laggy as some think.
All we know is no one who has a engine the as the same spec as ours has gone from GT-SS's to a 33D turbo kit, I'm looking foward to seeing what the results are.
Yes there will be more lag but a GTR engine was designed to rev. With our SS turbos max power was at 7500rpm.
I'm sure the max power of the 33D is about 850-880ps.
We will be running up the car with the JUN plenum then with the Hypertune plenum and 97mm TB.
we may also be going to a 150mm intercooler as well.
Just wondering what other cars on this forum have a setup somewhere near the same as ours which has a T88 on it or something else big.
Cheers
I went for a spin with Dexter in his Maroon R32 with a 2.7ltr kit and t88-33d.....response was great...top end was awesome. Ben id say you have made a wise choice with the 33d mate...can't wait to view the results.
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
