I have done a search as much as I can with the slow ass dial up I am currently using and have come to the conclusion that +20 offset in wheels 18x8.5 and 18x9.5 will not fit a R33 Gtst. I have been considering a second hand set of wheels in this sizing and the seller is convinced it will work.
Can an idependant source confirm/deny for me that it wont work without pumping the guards.
Thanks
+20 offset is GTR territory just to confirm.
<----- I've got 18's and they're +38's and fit as expected on a GTSt. (even squeezes 265's on the back which is a 9.5" wide rim).
Edited by ActionDan
Ok, I will be able to give you a more definative answer to this real soon as I am trying to fit 19x8.5 and 19x9.5 with +25mm offset. :D But to tell the truth, I am pushing it how it is.
Not quite 20mm offset but close. To tell the truth, I am pushing it how it is.
I have rear guard rub, getting them rolled shortly to see if this stops. And the inner gurds rub when cornering tight turns, looking at trying to remedy these probs.
With a +20mm offset, I doubt you'll fit em as they'll stick out a further 5mm, depending on type of rim and tyres.
I'll let you know how I get on.
Just thought I'd add that my car is lowered 50-60mm on Tein shocks and springs.
Edited by rocketboy
Yep, I think you'll be pushing sh#t up hill if you try to fit those suckers on. I am having front guard rub , rear were lipped/rolled and are now fine though. I have a 235/35-19 on the front, I might try a smaller tire (225/35-19 0r 30 profile) to remedy this problem. I really don't want to give up these rims!!
Yeah not going with them now.
Have decided on 35 and 38 offsets. Wont be as deep dish look but will fit.
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
