Hey everyone im selling my turbo as im gunna upgrade to the SPL model, its brand new never used, has only been mounted on my car, comes with chrome plated front housing and custom billet bellmouth which has also been chromed..
$5000
specs as follows
HKS T51R KAI - 800 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 70.3 Inducer / 94.0 Major
-Housing- 100 Inlet / 80 Outlet
TURBINE:
-Wheel- 76 Trim - 82.0 Major / 71.4 Exducer
-Housing- V-Band inlet / V-Band 115.5 mm outlet - 1.00 A/R
https://www.sau.com.au/forums/topic/108645-fs-hks-t51r-kai-ball-bearing/
hmm, what a nice responisve turbo for a small displacement 6cylinder engine. lol
it looks very nice though
when would i expect boost, aboutt 100rpm after the redline maybe.
what hp is this turbo rated at again?
turbo is rated at 800hp, on my engine i was expecting full boost around 4300-4400
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
    • Hmmm. that's a tough one. There's a lot of history bundled up in that lot. Perhaps instead we can create a new pinned thread, called "Legacy Pinned Threads" and provide links to the these ones that will be unpinned in there. And maybe put the names of the pinned threads that are linked inside in the tags so they can seen from the outside? Or something like? I mean, it's half a step back towards having a more complicated forum structure, without actually having it. But there's a reason that heirarchical architectures exist. They are logical, and if executed properly, make it easy to find something without having any upfront knowledge of where it would be , and without using a search function.
