blur Posted March 7, 2006 Share Posted March 7, 2006 Hi all, i have a r32 gtst that i have fitted a r33 style rb25det gearbox to. the r33 has a electronic speedo whereas the r32 has a mechanical drive. is there a way around this as the r33 type speedo drive is much longer than the r32 type. is there one out of another car i should be using?? has anyone else performed this conversion? Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/ Share on other sites More sharing options...
Bl4cK32 Posted March 7, 2006 Share Posted March 7, 2006 (edited) use red cog off bottom of r33 speedo drive. Get a 32 gtr speedo drive. Cut buff coloured cog off gtr drive, install red r33 cog onto gtr drive. screw in r32 speedo cable. Done. Ive done a post in the past, i'll try find a link. photo below shows red cod of r33 speedo drive installed onto r32 gtr speedo drive on left. On right is std gtr speedo drive. Edited March 7, 2006 by Bl4cK32 Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2002136 Share on other sites More sharing options...
blur Posted March 8, 2006 Author Share Posted March 8, 2006 thankyou very much, i will try and source a gtr speedo drive now!! Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2002378 Share on other sites More sharing options...
Shaun Posted March 9, 2006 Share Posted March 9, 2006 You can actually buy them from Lincorp Automotive for $100 delivered. The part has the R33 gear for the gear box but uses the R32 speedo drive. They did, however, send me the wrong one, so i had to swap the gear off the R32 speedo drive. Pretty easy to do. Speak to Tim 02 96845777. Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2005931 Share on other sites More sharing options...
neo32 Posted March 10, 2006 Share Posted March 10, 2006 u can order from nissan direct pm me for details Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2009492 Share on other sites More sharing options...
dangerous_daveo Posted March 10, 2006 Share Posted March 10, 2006 Stuff paying that much! Go get a nissan navara one for $20-25 brand new. Do the exact same thing as Bl4cK32 said, just with a drive that is new, and a lot cheaper! Part number = 32702 - 02G17 pinnion assembly. If you dont already know you will also need a new clutch slave cyl, you will need the R33 one that matches your gearbox. Now as I have just saved you money, please forward $25 to my account Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2010664 Share on other sites More sharing options...
kwazza11 Posted March 11, 2006 Share Posted March 11, 2006 alittle off topic, but can you keep your r32 clutch and flywheel when you fit the r33 gearbox? Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2011227 Share on other sites More sharing options...
Bl4cK32 Posted March 11, 2006 Share Posted March 11, 2006 as long as the rb25 box uses a push style clutch, yes. Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2011258 Share on other sites More sharing options...
ahapartridge Posted March 19, 2006 Share Posted March 19, 2006 I am a little confused by this.. In this pic I have a R33 GTST drive at the top and a 32 GTR drive below the thing that confuses me is that the gears are oriented differently, is this going to work if i swap the drives? Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2031995 Share on other sites More sharing options...
NateR31 Posted March 19, 2006 Share Posted March 19, 2006 you can also use a VL turbo one, thats what i used with my R34GTT box into my 31 Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2032036 Share on other sites More sharing options...
neo32 Posted March 27, 2006 Share Posted March 27, 2006 32702 - 02G17 pinnion assembly this part is the same as vl turb it has the wrong number of teeth ex japan from nissan change the 17 on the end to a 21 and there u go now anyone out there find this usefull please send me some cash it took a lot of buying of holden and nissan parts to find this out ah yes i have a r33 turbo bot in my 32 and my speedo works and its bang on accurate 21 tooth std 21 tooth replacement Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2052250 Share on other sites More sharing options...
ahapartridge Posted March 27, 2006 Share Posted March 27, 2006 32702 - 02G17 pinnion assembly this part is the same as vl turb it has the wrong number of teeth ex japan from nissan change the 17 on the end to a 21 and there u go now anyone out there find this usefull please send me some cash it took a lot of buying of holden and nissan parts to find this out ah yes i have a r33 turbo bot in my 32 and my speedo works and its bang on accurate 21 tooth std 21 tooth replacement So can we clarify that the combination of drives i was going to use as in the piccy is not going to work? They are both 20 tooth Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2052719 Share on other sites More sharing options...
R31 POWER Posted September 15, 2006 Share Posted September 15, 2006 I am a little confused by this..In this pic I have a R33 GTST drive at the top and a 32 GTR drive below the thing that confuses me is that the gears are oriented differently, is this going to work if i swap the drives? Im interested also!! Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2500394 Share on other sites More sharing options...
T04GTR Posted September 16, 2006 Share Posted September 16, 2006 use a s13 ca18 manual speedo sender in the r32 box Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2501131 Share on other sites More sharing options...
T04GTR Posted September 16, 2006 Share Posted September 16, 2006 red = 4.11:1 diff ratio the s13 ones are all eletric. and the plu is the same Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2501133 Share on other sites More sharing options...
T04GTR Posted September 16, 2006 Share Posted September 16, 2006 woops wrong way around. 32 gtr sender will fit i think Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2501137 Share on other sites More sharing options...
T04GTR Posted September 16, 2006 Share Posted September 16, 2006 or a vl turbo one Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2501138 Share on other sites More sharing options...
Sydneykid Posted September 19, 2006 Share Posted September 19, 2006 Im interested also!! Yes, it will work. The R32 speedo drive is on top of the output shaft and the R33 speedo drive is below the output shaft. So the teeth have to be cut for the reverse direction. cheers Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2509927 Share on other sites More sharing options...
ahapartridge Posted September 19, 2006 Share Posted September 19, 2006 Yes, it will work. The R32 speedo drive is on top of the output shaft and the R33 speedo drive is below the output shaft. So the teeth have to be cut for the reverse direction. cheers Good info, cheers gary Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2510686 Share on other sites More sharing options...
FATGTS-R Posted September 25, 2006 Share Posted September 25, 2006 32702 - 02G17 pinnion assembly this part is the same as vl turb it has the wrong number of teeth ex japan from nissan change the 17 on the end to a 21 and there u go now anyone out there find this usefull please send me some cash it took a lot of buying of holden and nissan parts to find this out ah yes i have a r33 turbo bot in my 32 and my speedo works and its bang on accurate 21 tooth std 21 tooth replacement I am also still confused. Neo is saying the part number ending with 17 is incorrect and it needs to end in 21, hence 21 teeth as this number of teeth he says will make it accurate. But what has how many teeth on the end of it got to do with anything as isnt the idea to cut the gear off anyways? Or have I missed something? Looking up Nissan part numbers and specs the 32 GTR sender has 20 teeth whereas the 32 GTS4 has 21 teeth. But as I said it dont really matter does it? Or has Neo not used the 33 cog and installed the Navara 21 tooth sender assembly complete and unmodified? I need to order a sender this week and want to make sure I get what is required. I will give this Lincorp a call as well and see what he has to say. Link to comment https://www.sau.com.au/forums/topic/108692-r32-gtst-gearbox-conversion-to-r33-manual/#findComment-2528575 Share on other sites More sharing options...
