Hi all , have any of you mounted an external wastegate down close to the engine pipe rather than up on your manifold away from disapproving eyes ? I was thinking this would look a bit less agro but still work as it should . The problems may be supporting the weight of the gate and dealing with different expansion rates of main and gate outlet pipoes . A friend once suggested using a smallish exhaust pipe flex joint to give it room to expand and contract - sort of a soft point .
I've no idea how cuddly a single turbo R32 GTST is down around where the 3" engine pipe would go but is there any chance of it fitting ?
Also have an old Turbonetics catalog that shows a "Deltagate Maxima" which is basically a throttle valve in a piece of pipe with V band fittings . It has a diaphram on the side with a sort of short rod integral actuator style linkage . If it does weigh 3lbs and is not too huge it could work in this situation .
Any feedback appreciated , thanks Adrian .
What type of manifold were you considering (high/low)? It's pretty tight in the back corner of the engine bay but if you mount the turbo high you will have a heap of room.
Even mounted low and forward as far as possible there is a reasonable amount of space behind the exhaust housing. I think the biggest issue would be making sure the turbo isn't mounted in the centre of the available space but over tight to the block as well (or even angled slightly to bring the exhaust in closer to the block). You would then have room to loop the wastegate pipe around between the front pipe and the inner guard and mount the wastegate right down low and upside down with the outlet pointing straight at the back of the car.
Alternately, mount the turbo out a bit with the wastegate pipe tucked in close to the block. That would also give you mounting options for additional supports.
mine sits way down near the cross member, with the outlet of the wastegate about 2 inches from the exhaust pipe.
not really a place thats hidden if you look under the car, but its plumbed back so not EPA illegal.
that looks really really low, suprised if it doesnt get ripped off from speedhumps, steep driveways.
mines the same but much more tucked in for more clearance, heres a pic...
yeah it looks it in that pic, but it is above the bottom of the exhaust as well as above the cross member.
have to see how the new WG fits.. the one in the pic is SHIT.. faulty and leaks/sticks ..
i can move it up higher if i want, depends on what WG i replace it with.
yer looking at it compared to my pic it doesnt look much lower, i think its the angle of the photo making it appear to hang way down.
cheers
Might not be the sort of thing you are after but this is a 35mm gate on a high mount manifold, RB20 R32. I just took the manifold off again but ill take a pic from underneath tomorrow when i get it back on.
Low mount and max 3" engine pipe .
Out of curiosity what size HKS gates are those and what tube size for the gate ? For the one that is plumbed back do you have expansion and contraction problems ?
Thanks A .
mines a 50mm hks gate, and the tube size is 2" :/
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
