i have constant access to avgas due to being involved in racing boats. wondering if anyone knows if i can use 5lts or so in every tank as an octane booster? car is a 33 with minor mods, cat back 3.5, hks pod, blitz bov and running 10psi
also.... would i do any damage to my car running it on straight av for events like nats and track days? heard it can burn out cats or o2 sencors or sumthin!
cheers!
Brett
https://www.sau.com.au/forums/topic/108717-avgas-is-r33/
avgas is a lead based fuel isnt it?? hence would not work...:S
lead based doesnt matter as far as i understand. It's just illegal
AV Gas i dont think would yield any benefit. Unless the car is tuned for it, you really arent gonna see a lot of improvement.
No sure about burning the O2 sensor, someone will know for sure :D
https://www.sau.com.au/forums/topic/108717-avgas-is-r33/#findComment-2002732
o2 sensor will die a orrible death,
avgas is no longer lead base...... its lead free..... the octane level has dropped quite alot since the removal of lead .. i think its down to like 104 or something.... where it used to be aaround 115 in the early 80s and 90s.
ur really not going to see much of a gain ....even by tuning it ... ur not going to run avgas everyday.... and for 180cents a litre u might as well run methonal and water injection.
https://www.sau.com.au/forums/topic/108717-avgas-is-r33/#findComment-2002755
OK, AVGAS is a DRY fuel, thus you should never go past a 10% mix as this will cause problems with fuel lines, fuel pump, injectors and so forth. Too much CAN actually cause more damage than the "perceived" benefit.
Also as it is a "dry" fuel it does not actually "mix" with the other fuel in the tank (similar to oil in water), however, that being said as both are fuels in the broader sense they do interact.
There is a slight performance gain, similar to that of using toulene or ethanol, it reduces the chances of knock and detonation and allows greater timing advance.
I have used this in many cars, purely at the track and NOT for everyday driving as the constant use is not good for the fuel system as mentioned previously.
Finally, with regard to the O2 sensor, too much avgas will not only see the death of this but also your cat. However, these effects are SIGNIFICANTLY reduced since avgas is no longer lead based. Thus a 5-10% mix, not on a constant basis should not have an effect.
I usually run 5% and have never had an O2 sensor fail, nor any other fuel system problems, I have seen 50/50 mixes do some nasty things to fuel pumps though...
https://www.sau.com.au/forums/topic/108717-avgas-is-r33/#findComment-2003109
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
