okai so i jsut relised wen i turn the car on. on the dash is says "SLIP" and "TRC OFF"
wat does slip mean....
i no wat the TRC OFF means...but the thing is...i got a button under the wheel to turn it on...but wen i press it it still says OFF....isnt it suppose to be on at all times unless i press the button which means it goes off?
https://www.sau.com.au/forums/topic/108799-r34-problems/
You've got a problem and more than likely a big one. Chances are it's your coilpacks but best bet is to take it to a nissan dealer so they can plug in and see what the problem is.
R34's have switchable traction control its on the lefthand side next to the steering wheel. When the TCS is on the "SLIP" light will come on when it senses wheelspin. When the TCS light is on and it displays "TCS off" the slip light will not light up at all, but the car will do burnouts and whatnot.
I don't beleive any of the R33's have traction control, maybe the one's with an A-LSD do but i'm not sure, all other ones do not have traction control at all.
Edited by kralster
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2004534
TCS & Slip light normally means there is a problem with the plug that attaches to the secondary throttle butterfly under the bonnet, unplug it and plug it back on see if the lights go back to normal.
Run a diagnostic check to see what error code comes up
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2004746
  anjoO said:
can i take it to any nissan dealer?
i swear i just got the car...and im already havn probs lol
If u just got the car, bring it to a mechanic or nissan who have the scan tool and get it checked out quick smart. If the car was from a dealer it should be covered by warranty.
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2005103
This is a common problem with the R34s - a lot of owners have come across this at one stage.
For me it was as simple as making sure the wires were connected correctly and firmly at the ECU. This was after the SAFC2 install where we hadn't tucked all the wires back neatly - it could be a range of other things too but that was my case.
Since fixing the wire arrangement, I've never had that problem again.
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2005784
Nope none of the R33 range comes with traction control, not even the ones with the A-LSD, my mate has one and his doesn't have it
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2007615
I am mistaken ><...nyways the secodary trottle, is that how a TCS works? the secondary valve automatically cuts off the air when the car senses slip?
so if I replace the TB to say Q45, will the TCS still works?
Edited by SKY 34
https://www.sau.com.au/forums/topic/108799-r34-problems/#findComment-2013627
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
