How right you are! I have been addicted to this game for a month. There is just so much you can do and the world it increadible!!
A mate of mine plays World of Warcraft, says its more addictive then crack....im not going to touch it! :
Yeah my bro plays ONLY those two game (oblivion and WoW)
I'll prob ably install the full hitman 2night and post up some screenies if you guys want.
On another note i'm using Windows Media Player 11 at the moment so would that effect anything to do with me not seeing a score on 3Dmark 06?
I been playin HEAPS of The Godfather in the past few days! Awesome game! But i'll see what Hitman is like and add to the positive feedback (if it deserves it) 2night.
Yeah thanks mate,
Ok this is what busky helped me out and we are looking at, I know it's pretty low spec, but it'll do the job
Shuttle SS59G - $268
Gen Ram 512Mb DDR400 - $65
Intel Celeron D331 2.66G/533/256K LGA775 EM64T XD CPU $109
Samsung 160GB HD SATAII 7200rpm, 8mb Cache $115
LG (4167BBK) Black 16X +/- RW/RAM DVD Burner, Dual Format Double Layer, OEM with software $62
Microsoft Basic Value Pack Optical(OEM) Inc Keyboard & Optical Mouse PS/2 $ 37
All up $656, then $35 delivery
So if your mate can get me something similar or even the same for less, it'd be great,
Oh it's for a business so an invoice would be needed if over $500, but if secon hand comes up under that, cash should be fine.
Cheers
MIGHT be able to hook you up with something
Warranty the whole shabang
Mate has his own small business, i'll have a look at his supplier list and see what he has got.
Just Motherboard, Processor, RAM and HDD?
I have been playing "The Elder Scrolls IV - Oblivion" for the past 4 hours - boy it is an addictive game!
I played this for quite a while until i comlteted the main part quest and then got bored of it for the time being
Well here is A pic of Hitman Blood Money i was gonna post.
Only started playing it last night and up to the 3rd mission so far.
(Sorry about the size but i thought i might post it how i play it)
And here is a pic of Spliter Cell - Chaos Theory
VERY GOOD GAME! (dunno why is print screened in this size but hey)
Only up to the 1st level in this cause its actually resonably challenging
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
