Adaware is what cubes is referring to Madaz when he says the bill board advertising. Basically the spyware logs how long etc u look at the ads etc (im going to shoot all i go past...take that EA :)) and sends the info out...
Im unsure if i wanna grab the patch sorry...full game :P Already been playing the demo for a while...not bad, but my computer is relatively new (by date i bought it i mean :)) and ive heard others have had problems...whats so new :D
Ive been playing guild wars more than anything atm....
yeah i have heard nothing but troubles with the full retail
thats probably why the demo was so lite ...
no revive for medic only a 3 kits no nades all the things that helped create bugs
prolly no PB too
I hear you madaz, i do it with my legit copy of games. I buy all my games, so i can network play it.
There are lots of freeware iso program making software (e.g. isobuster) and alot of low cost ones (like 30 bucks for winiso).
so wheres SFII i loved that game
i used to play if for like 40c @ a small foodland when every where else was 1buck :P
looking into isobuster
so can i put all my disc's to DVD and when install not remove the dvd and the install procedure find the relevant cd on the dvd
lmao.. Awesome Howie..
Madaz.. Yep the only way is via Alcohol 120%.
To save those origionals create mini images (very small) keep them on your HD and mount them via daemon tools to play the game.
I personally don't see the point of copy protection with games that are primarily online based. A simple cd key check as per bf2 etc is all that is needed. Spend the $$ on creating a better bug free game or pass the savings on to us to. :P
I know if a game was around the $50-$60 mark I would buy more games at that price and end up spending more doing so compared to only buying one or two games when they are worth $80+ each.
SF2 is like my all time favourite game! :P Should drop by one time if you ever have the urge. I run mame, so all the versions of SF are there (hyper fight, alpha, alpha2, super, etc). I've also spent a bucket load on quality happ joysticks, so it's authentic.
Oh yeah, daemon tools is an awesome freeware iso busting program.
Wanna see my other rig?
I've got it in a vectorised Adobe Illustrator file, I think photoshop should be able to rasterise and import that.
http://www.howiefied.net/sau/sticker/final/
Lol... i got in with the group buy on dell 24's.. i think we ordered about 500 of them on overclockers australia.
When i'm done with my other rig, i'll take pics of that too... it's a home theatre pc, with onkyo amp, accusound 5.1 with sub, and in not too long a 42" hd plasma.
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
