i use coolant... car coolant. lol. best temps i would be getting during summer would be from today so ill see how good it runs when theres a great delta temperature, and airflow coming from outside over the radiator.
ah cool mate, sorry I misinterpreted what you said .... Thermaltake cases/PSUs ftw :happy:
I haven't used their water cooling products, but find their heatsinks/fan setups to be very good. I never got into water cooling, always found the idea of water running through my PC way too scary!
yeah you dont have to run water in them as mentioned earlier alchahol/mix has no freezing point and chills more than water
well if u really think about it all u need is demineralised water and something to stop stuff growing in it. Your room would never hit 0 deg celcius to even freeze normal water :happy:
edit/ and as long as it wont react with any metals used in the loop
Edited by Bl4cK32
SAZilla,
What vid card and hows it clock with water vs std air? :laugh:
I've never bothered with water cooling but always wanted to have a play one day..
My overclocking adventures in the last ~12yrs have never seen a failure, I put this down to never using water, even when using a decent hsf heat becomes an issue before volts so your never really able to run enough volts to kill a chip.
im running a 7950GX2 video card, the "sandwhich" card. it is 2 7950 cores x2 on 2 PCBs which are sandwhiched together with 4 tall pins on 4 corners of the boards and a small PCIe interface in the middle of the card that links the two together. I cannot water cool it if i cant fit waterblocks inside the middle of the card and i dont overclock that card at all anyway cause im looking at selling it. the only waterblock at the moment i have is on the CPU cause im kinda trialling thermaltakes product.. the rocket.
last night it was at 33 degrees idle, and 40 degrees load, this is acceptable cause 22 degrees and then like 14 degrees at night is a normal winter/autumn/spring kinda weather on average and i can deal with that... but when the room abience is 30 degrees the idle temp is 48! the load temp 56! the cpus rating is only 60 degrees so its kinda dangerous. I should have gone with a radiator with a fan but i wanted to have no sound but the GFX cards fans. mind you.. my graphics cards idle temp is par 50 and load is 62. my computer runs very hot with these parts inside. last night was the first night in summer that every temparature stayed below 41 degrees and the HDD temps were 23 and 23 a piece (2 SATA2 HDDs 320gb)
performance can be much greater if you select the right equipment, and if u clean everything and install everything properly you will have no issues whatsoever with water cooling and there is no possibilty that anything will go wrong if it is maintained corectly.
Edited by SAZilla
im thinking now about how to utilise a car radiator for my system and a custom pump. i want to mount the radiator outside the house and thru my window run the pipes into the computer and have this driven by a better 12 volt pump thats alot stronger. my mate who has a sil80 said why dont u just intercool the f**ker and i said im not crazy. this is kinda a hobby for me until my case becomes a fish tank.
I toyed with the idea of using an old car heater core (head down to U-steal it wreckers and pick one up cheap).
lol at the car rad idea.. Massive. Keep the shroud attach an old solid radiator fan to an old washing machine motor and your set. :laugh:
it would be easy to set up one from pool just need some long ass plastic tubing and the 12v pump would be enough. ill try it from a bucket tonight and see what happens, at least there is no chance of the lines bursting or caps falling off cause there is no pressure build up
Edited by SAZilla
I was planning to use an old heater core I had lying around. A good resource is overclockers.com with a list of didferent car models, dimensions and inlet & outlet diametres. The articles a bit old but you get the idea
http://www.overclockers.com/tips1031/
I've seen other kits with a 40L plastic bin next to the PC with 2 hoses in it. Worked quite well.
Edited by L3nny
yeh take it... probably just needs some caps changed lol and a new fan.
i just completed the test... the results are clear. i went from 44 degrees idle to now 33 degrees idle after 2 hours of comp being on. my setup is the thermaltake rocket water cooler radiator sitting in a bucket full of water (like an internal resovoir of some sort), then a tube going in the radiator and then from the radiator into the bucket then the bucket into the CPU block lol. lmao i should get some pics up wait on lol. :(
Edited by SAZilla
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
