get a Ninja Case :laugh::D
http://www.pccasegear.com.au/prod3033.htm
somthing like this PSU will do fine no need to go over the top that GFX card doesnt even run its own molex
http://www.pccasegear.com.au/prod3598.htm
i just remebered b4 ive used this ebay seller is very prompt and is in adelaide to
Ebay PSU
EDIT
Vista Home Premium
i bought a copy of XP of him and bould buy more things
EDIT
Mobo CPU and Ram combo
Edited by Madaz
so, i has a small problem.
well, a few small problems.
1. my connection speed is as low as 1mpbs. (using a belkin 54g, a few hours ago it wouldnt connect, period, stuffed if i know how i managed to connect).
2. most of my usual sites load, with the exception of the r31skylineclub... and i know that isnt down.
so, any suggestions and such?
A few things to try off the top of my head...
Power off/on the modem
-If sync/speed is still bad disconnect every phone in the house from the phone line and power off/on the modem again and check sync speed.
--If it improves you know you have a dead line filter (not common but does happen). Isolate the dead line filter by connecting a single phone at a time and calling it with your mobile while watching for sync/speed drops and transfer interuptions.
Are you on ADSL2?
-Change your line profile to a 'reliable' profile to improve stability as they ncorporate interleaving which as a result increases ping so not so good for online gaming but its better than having poor stability.
Changing the line profile to reliable profile works well on those wet days where water gets in to the lines causing a little cross talk that results in poor stability/reduced sync speeds. I've had to do this almost every winter :whistling: Then wait for telstra to get out and fix the lines. In the last recent downpoor the phone line dropped out completely, unable to receive or make calls (no dial tone with lots of crackling and static) I called internode had them throw me on the very high reliability line profile and I connected at just under 1mbps. It took 3 days for telstra to sort out the problem. :S
and ....... Call your ISP. :)
well, unplugged all the phones and such, the connections a little better, but its still slow (>12mbps) and its still fairly unstable, but its better than it was 10 minutes ago, ill call belkin and internode tomorrow and see whats up.
i doubt its internode though, looks more like the routers f**ked, had so many problems with it...
Linksys, Billion & cisco (out of reach) modems for me. I prefer billion modems.
Always have a quick look at
http://cgi.internode.on.net/advisories/list.html?area=1
to notify of any issues.
Most likely the telstra line that runs from the internodes hardware in the exchange to your modem/router.
In the meanwhile if transfers web browsing and transfers are unstable throw yourself on a more reliable line profile (done via internodes web site and monitor when the modem resync's on its new more stable line profile)
You should be fine with the high reliable profile, very high profile may be a little overkill.
Failing that do the usual virus scan & spyware/malware scan.
spyware/malware - lavasoft adware, spybot and the VERY usefull prevx1.
If your familiar with services that are supposed to be running hijackthis is also a handy tool to use. I tend to use all three on problem computers.
try looking @ a Mitac EL80 one of my mates bought one and he was very impressed there is also overclockers AU did a review and other boards that you can google
i had links for you but i dont know what happened if i closed browser before submitting doh!
...so far netgear seems solid...
I've had good experiences with netgear stuff too.
While I haven't used a WIDE range of stuff, the products I've used have always perfomed as I'd expect them to, with no issues.
That's all I really ask for in hardware, and for the price I'd recommend them.
This is usually the part where 5000 people chime in with "XYZ is so much better", and while they may be, until I find a product doesn't do something I need, it doesn't need changing.
alieware are sooo overpriced but its your money
my mate bought one of there P4 3.6 laptops over a year ago think weighs like 14kg comes with it own backpack cost him 4g had like a 7800gtx or something in it
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
