I recently had a good experience with a DOA antec psu in an 4480 antec case with MSY.
Basically powered it up once turned it off then it wouldn't power up again. Tested the psu and it was definitely stuffed.
So i called them up dropped the case off they tested it and gave me another; no fuss no questions all done.
I've been fairly lucky with DOA computer bits over the years. The last DOA I had was 2 sticks of DDR corsair ram. :laugh:
been having a look at some ferrari 430 software this weekend. Some pretty in depth stuff there. Unfortunately it had a mind of its own and seemed to take control of the car. in qualifying it was controling the brakes when it wanted to brake (not that helpful down the straights when the cars brakes are locked on) and the in the races it decided that it would go into neutral instead of the gear it was meant to - see what happens when you rely to much on computers.....
it makes you ferrari slow!!!!!
oh and i found the laptop i want, the Lamborghini Asus specially developed to work with the Gallardo software and diagnostic tools. it has a sexy carbon outer case with the raging bull embossed into the top
On the 2nd episode of Blood, Sweat and Gears the guy in the Ferrari spun it on a slalom course, and the car ECU shut the car down as the wheels span and it turned too violently. They had to get a Ferrari tech to reset the ECU to start the car again! Definitely far too much computer 'control' for me - who would want such a thing?
My mate had the ECU reset and had the software reinstalled 3 times over the 4 days. I like the ferrari dash read out, very classy in red and black, then you walk up to the historic's that still have these funny dial things on the dash to show them how fast they are going :laugh:
during the race this morning one of the 430's ECU shut down and they had to restart it, once they did that the car went into limp home mode which wasn't very good during a race.
Ferraris and computers obviously dont mix too well. Keith Wong had some serious issues on Thursday & Friday because his 360 has 3 computers (2 engine management and 1 driveline). One for eack bank so it sees it as 2 separate engines. The thing kept shifting into 'Limp Mode" everytime he hammered the rev limiter. So by trying to stay off it meant he couldn't go as fast. You cant even plug a laptop into the thing unless you've got the unit that can communicate with the ECU and thats in Melbourne.
No wonder the Porsches keep giving it to the Ferraris and they don't break down anywhere near as much. Keith had a gut full and was tempted to bring out the Porsche that he did well in last year. Poor bloke probably regrets buying this thing.
Keiths car from last year is no longer eligible to run in the series. The 360 Challenge is a good car of you have it sorted right finished 4th in last years event in front of some much higher rated drivers. Marc Eddy is happy that he upgraded it to the Gallardo though (3rd outright for the weekend) i had a quick look at the Gallardo's data collection software and hardware today. You can either plug the laptop into the car or you can remove the memory from the ECU and tale it over to the laptop (what eve is easiest).
and here i was thinking Keith was just cruising trying to get used to his new car
Edited by Whiplash
  • 3 weeks later...
came accross this game yesterday its a MMORPG add some more letters :thumbsup: little bit fun though and you can drift and get points though i havnt done too much drifting becuase its a race game object is to be fast
the actual download isnt very big @ 491mb but its @ least that again or more in updates
>>Project-Torque<<
>>My Profile<<
anyone else have issues with MSN live this week? its asking for a critical update but i can't download it from anywhere :thumbsup:
and yes i have a genuine copy of windows and it hasn't come through under an automatic update
damn cable runnin slow.
how many ppl deal with msy comps in the city??
coz im lookin at builing a comp soon and wanna know wat parts i should get n who i should get em through
wat does MMORPG stand for??
Edited by SLY-dN
does anyone know a good source where i can get the "Windows Update Agent" that isn't a Microsoft website? for some reason my ORIGINAL COPY OF WINDOWS XP won't download anything from their sites :)
This is pissing me off now. I tried downloading the new version of IE to try and access the site but i need the update to install it :thumbsup::D :D
I HATE COMPUTERS
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
