Well then....Gotta ask few questions.....
1. Is $2/hour ok for everyone?
2. What games you guys like? We've only got these games (See below photo)
3. Obviously Arena won't be able to provide "parking spots" for SAU Lanners, so is it ok for u guys to park ur car either on Rundle St or in the car park down in Union St (like 20metres away from Arena)??
4. Overnight LAN or.......? You guys pick a good time for everyone...
5. Now.....How many wants to come.......?
P.S. Coffee machine is fooked, so no coffee, can go buy em from downstairs, we've only got soft drinks and lollies, also instant noodles for someone who's hungry at night.
Anyone want high def youtube video?
if you add "&fmt=18" on the end of a you tube url it load a high def video instead of the lower quality. Its not as noticeable on all videos. Once you add the &fmt=18 to the end of the url it gives you an extra option bar under the video to choose the quality (small tv icon next to the number of views).
Low Resolution
High Resolution
not a massive difference but it could help out with some dodgey videos
ill be there, any time, any game(2). dont care about parking either.
Sounds like u put on a good show mate :D
$2 an hour is no worries at all,
although not heaps good at them i like FPS
my car might be off the road, so parking is no big hassle, but a close park on rundle, or union street is fine by me
night time is definitely a go
IM IN :P
Any public holiday or long weekend coming up anytime soon? Cuz Saturday, most of the peeps would go out and go sick with the alcohols (including myself), therefore Saturday night is no go. Friday night, unless you guys come after 10PM, otherwise I can't guarantee everybody a spot. Well, it's you guys' call!! :)
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
