does anyone know how to setup a mic? my mic was working fine until i did something and it ferkd it up, so now weneva i record or talk over the mic everyone can hear what im hearing through my headphones when they shouldnt be. help please >.<
yeah I wouldnt bother with quad cards. but two in sli would be nice.
jsut want to play crysis with nice frame rates.
call of duty already looks nice on the 8600gt. but It would look alot better with high resolution.
Almost better off selling the 8600gt and buying one 8800gt as one 8800gt kicks an sli 8600gt setup.
all the nohaxnetwork servers are good
my name is MR.MADAz
you can find me in NohaxNetworks Ventrilo
IP: 144.140.154.69 PORT: 3875
you will need to right click my name and send user page and i will hear you
i also play alot of SOF2 on PTGN Perth
i use the Arena to find my games :( i have Xfire but dont use it
my name is MR.MADAz
cool.
Been playin it on ps3 alot.
just started online with the pc. So alittle shit.
Will see you on there im sure.
I've played a bit of COD4. usually on the Internode servers. Apart from getting my arse handed to me they appear to be fine.
Recently bought a 22" samsung and the ol' 8600GT is struggling a tad at 1680x1050. Still does 'ok' though doesn't completely fall to its knees.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
