I'm with Adam as well Andrew with this result........big difference in Ping speed, what's that all about?
I upped the ante to Aggressive mode (ADSL2+) and it upped the ping rate slightly but dropped the download rate..........maybe time of day??
The ping will vary - 2ms is nothing. :D
Distance from the exchange.
My own service connects at a slower speed when connecting with ADSL2+ compared to ADSL1.
However connecting as plain old ADSL2 (without the +) it connects at its fastest.
What you need to do if your modem supports it is place your self on an ADSL2+ standard type profile that aims for an SNR of around 9-10 and then force the modem to connect 'only' in ADSL2 mode.
Doing so will generally provide the quickest connection at a longer line length.
LAN limited :P WOOT :(
bizarrely while my ADSL1+ gets a MAX of 4.5Mb/s on speedtest, sometimes I get download speeds as fast as 600kb/s in UTorrent, when downloading multiple torrents from a good source (like tvtorrents private tracker). I am not sure how I get such good speeds sometimes - yet have NEVER downloaded from the 'normal' internet (even direct from Adam or a pipe) at that 600kb/s.
Supposidly (got spelling) i'm on ADSL2+ with Internode and this is all I get living in Panorama.
Pretty pathetic in my opinion.
Ignorance is bliss.
All bets you are on the ADSL2+ Very High Reliability Profile and haven't changed it since day one. :P
Double check to ensure all devices connected to your phone line are filtered. The modem doesn't require a filter. Run a <3m telephone cable.
The ping will vary - 2ms is nothing. :)
LAN limited :P WOOT :)
Thats quick, dies anyone still use dail up, they were the good old day take a week to down load a pic of a car!!
Now now, before I had ADSL (still on 1, no 2+ here ;) ), I used to download several gigs of anime & movies using good old dial up.
It does take several days or weeks for the 700mbs, & people can't call the house (which isn't really a bad thing, considering all that telemarketing crap I get everyday).
Edited by Mayuri Krab
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
