  • 3 weeks later...
ok if any geeky tech heads are heading to melbourne the 8th of movember you may want to check out Swinburne University for the alien ware launch of Call of Duty world at war lan sound salot of fun :O
http://www.alienware.com.au/party/
taken from GameArena
best quote scrolling through the chit chat
i swear melbourne fking gets all the good **** , when does sydney get stuff like these?.
You guys had a massive parade of people in skimpy outfits just recently. Oh hang on they were all gaylords.... guess that's what you get for living in the gay capital of Australia.
ooooooooooooooooooooooooooooooooooooo
hopefully this installment isnt anything like modern warfare with its amount of online hackers
shall make for interesting LAN competitions
writeoff,
All speedtests really are is in indication of your sync speed. Internode/TPG you should be able to obtain the same sync speed providing the line profile you select targets the same SNR and using the same modem. Some modems connect up a good >1mb quicker.
Typically the ADSL2+ STD profile on internode targets an SNR of 9db. A nice balance between speed/reliability. The Internode highspeed adsl2+ profile targets an SNR of 6db. Still good reliability providing your copper run from the exhaust to the house and internal wiring/filtering etc is all spot on.
I've tweaked mine a little and have the SNR down to 3-4db. Holding stable for 8+days. :)
Well this is Adam internets 8mb plan as were in goolwa, no adsl 2 or 2+ for us here unless we wanna pay ten times the price for Telstra shit service and speed. My girlfriend was also using Second life at the time I did the test which sucks the shit outta my connection.
Edited by Stagstock
ok,
the missus has a computer that we had stashed away in the shed, i pulled it out
a little while ago and plugged him in
shit me, its works, and already has XP installed, its fresh, no files/programmes etc
now, i need to install my optus wireless internet driver, but i cant find it ;)
can i burn it from my lappy and install it on the other comp.?
or does someone have a driver i could possibly borrow?
:P
ok,
:P
copying the program files will not work
i work part time for optus and i know people high up so i can most likely get the software you require ,
the software you require , is it for an OWB ?
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
