hey Chops we should do another beer with Andrew sometime.
thanks for all the responses guys, I've checked a few reviews and am definitely leaning towards the logitech (buy it once I suppose)....just have to decide whether to get the Pro9000 or Orbit (Sphere)
Sounds good Pete.
Got a busy couple weeks, as the wife's about to deliver our first in a week or two - no doubt soon after I'll either be looking to celebrate or escape!
anyone else hear of the April the 4th virus in todays news paper just wondering what people have heard
If you're referring to conficker, its due to polymorph on the 4th however most AV companies are on top of it (and MS has released a patch to help prevent damage)..
I for one have been home all day with pharyngitis. If only I could run AVG on my tonsils I'd be much happier.
-D
hahaha i think a CF mouse mat would play havoc of the laser
yeah G19 looks nice i was never really into fancy keyboards
Same, I even prefer the corded mice and keyboards because I was sick and tired of constantly changing batteries in them.
It is a corded keyboard though Norman. I've used cordless keyboard and mouse before - the mouse chews up batteries mainly. The G15 V1 and V2 and G19 are corded same with their pro mouse the G9.
I got the G15 V1 - the G19 doesnt seem to be that much of an upgrade worthy of upgrading yet... my MX510 mouse on the otherhand - I so want the G9.
yeah i got the g15 v1 too.... only problem is the paint wearing off the keys ;\ I dont have an 'S' key anymore, its just a dot...
-D
Keyboard maybe but not on a mouse!
Agreed. I have a 5 year old wireless logitech MX mouse and it never stopped me from getting to the top 3 SOF2 players on the Telstra and optus servers back in the day. Gamers who blame their mice are really laughable :D
-D
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
