Just got my Creative X-fi extreme audio sound card. having probs installing.
Comp wont even detect the soundcard for some reason.
Win Xp.
anyone used these cards before ?
no diff between PCI 2.1 slot and normal pci and pci E ?
Win Xp.
I've got the Creative X-FI Fatal1ty champion series , probably the same...
make sure you have power plugged into the back of the card , if thats in and its still not detecting , try a different slot.
have you disabled onboard audio via bios ?
Ive disabled via system devices etc. Might be something to do with the slot on the motherboard.
Tried other pci slot and nothing comes on the screen.
Will try disabling via BIOS
Shouldn't matter if the onboard is not disabled in BIOS because you should be able to switch between devices in Control Panel.
Just double check that it's seated correctly in the slot
As I stated above I was trying to install my new soundcard. So I can have some crisp sounds for music production.
after about 234 hours of stuffing around I became impatient.
Tried clipping what I thought was alittle power supply to the end of the soundcard. did this while the comp had power. Screen went all funny so i switched it of quickly.
Now when I turn it on I hear all the right sounds but have absoloute nothingness on the screen.
lost some music and im going to cry alitte bit.
its not likely you've lost your data
reset the CMOS, you may have only screwed the bios settings
-D
Will try that.
Just dont want to go near the other comp for a few mins. It may end up on the road or in the oven.
I was looking around for maybe a small fuse I may have blown ? Dont some motherboards have em ?
OK so you hear a single beep when you turn the machine on and you get fans/hdd's spinning but nothing on your monitor.... At worst you've fried the graphics card. If nothing is happening (after what SLED has already advised) then you might have fried the Power Supply. Having re-read your post ^, there is a difference between PCI Express and PCI 2.1. PCI 2.1 slots are usually white slots on mobos and have a largish edge connector, most if not all PCI cards are compliant with 2.1. PCI Express cards have a very short edge connector and slots are usually black.
Also if you ever need any help/advise in regards to computer music production feel free to PM me... I've been doing this stuff for far too many years and have built and configured many digital audio workstations. If you don't mind me asking, how much did you pay for the creative card?
Still nothing.
hmm'''
I took out the Video card and went to onboard. Still nothing. so its not the gpu.
How exactly do you reset CMOS> maybe im doing something wrong.
I install all my own parts and never had this prob. its fkn annoying.
There will be a jumper switch located near the CMOS battery or between the pci slots - your motherboard manual schematic will point u in the right direction
download it off the net if u havent got a hardcopy
simply move the switch from position one to position two and back (while the unit is off)
same goes with jumper pins and jumpers, it'll be located near the cmos battery
yes there are fuses, but theyre located inside the power supply - i dont recommend you open that up due to the capacitance and AC current
-D
Easiest way to reset the CMOS is just to pull that button battery out from the mobo & leave it out for a bit & put then put the battery back in, that should clear up what ever settings were stored.
Alternatively depending on your mobo model, there is a specific jumper pin you have to set to reset the CMOS (have to read your mobo instruction manual for that). Some of the higher end spec mobos have a switch/button for it, instead of a jumper.
Good luck with it.
On a different topic, my GTX-260+ card just arrived in post today :D
EDIT: got beaten to it.
Edited by Mayuri Krab
Intersting. Usually when something like this happens at the end I always think Ive learnt something.
Tonight I havent.
Put the 9800gt gpu back in. Nothing.
Tried cmos battery method again. nothing.
Tried cmos jumpers. nothing.
I just cant put my finger on it.
That last screen I saw b4 all this happened did look pretty scary. Prolly fried something .
I even Tried clicking mouse buttons etc while the thing was running just to hear the HD running thru cycles. nothing again.
Tonight I havent.
well start with the obvious. change the power supply unit to another one, if its a matter of voltage regulation or fuses you'll know straight away...
next thing would be your motherboard but you'd have to find a place that has a spare thats compatible with your cpu and ram to eliminate that variable.
-D
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
