Just got my Creative X-fi extreme audio sound card. having probs installing.
Comp wont even detect the soundcard for some reason.
Win Xp.
anyone used these cards before ?
no diff between PCI 2.1 slot and normal pci and pci E ?
Win Xp.
I've got the Creative X-FI Fatal1ty champion series , probably the same...
make sure you have power plugged into the back of the card , if thats in and its still not detecting , try a different slot.
have you disabled onboard audio via bios ?
Ive disabled via system devices etc. Might be something to do with the slot on the motherboard.
Tried other pci slot and nothing comes on the screen.
Will try disabling via BIOS
Shouldn't matter if the onboard is not disabled in BIOS because you should be able to switch between devices in Control Panel.
Just double check that it's seated correctly in the slot
As I stated above I was trying to install my new soundcard. So I can have some crisp sounds for music production.
after about 234 hours of stuffing around I became impatient.
Tried clipping what I thought was alittle power supply to the end of the soundcard. did this while the comp had power. Screen went all funny so i switched it of quickly.
Now when I turn it on I hear all the right sounds but have absoloute nothingness on the screen.
lost some music and im going to cry alitte bit.
its not likely you've lost your data
reset the CMOS, you may have only screwed the bios settings
-D
Will try that.
Just dont want to go near the other comp for a few mins. It may end up on the road or in the oven.
I was looking around for maybe a small fuse I may have blown ? Dont some motherboards have em ?
OK so you hear a single beep when you turn the machine on and you get fans/hdd's spinning but nothing on your monitor.... At worst you've fried the graphics card. If nothing is happening (after what SLED has already advised) then you might have fried the Power Supply. Having re-read your post ^, there is a difference between PCI Express and PCI 2.1. PCI 2.1 slots are usually white slots on mobos and have a largish edge connector, most if not all PCI cards are compliant with 2.1. PCI Express cards have a very short edge connector and slots are usually black.
Also if you ever need any help/advise in regards to computer music production feel free to PM me... I've been doing this stuff for far too many years and have built and configured many digital audio workstations. If you don't mind me asking, how much did you pay for the creative card?
Still nothing.
hmm'''
I took out the Video card and went to onboard. Still nothing. so its not the gpu.
How exactly do you reset CMOS> maybe im doing something wrong.
I install all my own parts and never had this prob. its fkn annoying.
There will be a jumper switch located near the CMOS battery or between the pci slots - your motherboard manual schematic will point u in the right direction
download it off the net if u havent got a hardcopy
simply move the switch from position one to position two and back (while the unit is off)
same goes with jumper pins and jumpers, it'll be located near the cmos battery
yes there are fuses, but theyre located inside the power supply - i dont recommend you open that up due to the capacitance and AC current
-D
Easiest way to reset the CMOS is just to pull that button battery out from the mobo & leave it out for a bit & put then put the battery back in, that should clear up what ever settings were stored.
Alternatively depending on your mobo model, there is a specific jumper pin you have to set to reset the CMOS (have to read your mobo instruction manual for that). Some of the higher end spec mobos have a switch/button for it, instead of a jumper.
Good luck with it.
On a different topic, my GTX-260+ card just arrived in post today :D
EDIT: got beaten to it.
Edited by Mayuri Krab
Intersting. Usually when something like this happens at the end I always think Ive learnt something.
Tonight I havent.
Put the 9800gt gpu back in. Nothing.
Tried cmos battery method again. nothing.
Tried cmos jumpers. nothing.
I just cant put my finger on it.
That last screen I saw b4 all this happened did look pretty scary. Prolly fried something .
I even Tried clicking mouse buttons etc while the thing was running just to hear the HD running thru cycles. nothing again.
Tonight I havent.
well start with the obvious. change the power supply unit to another one, if its a matter of voltage regulation or fuses you'll know straight away...
next thing would be your motherboard but you'd have to find a place that has a spare thats compatible with your cpu and ram to eliminate that variable.
-D
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
