Hoping that W7 kicks ass on 3 x 36Gb raptors striped, even on a lowly Quad core Phemon 9500! If only the x86 would see more Ram I would add another 4Gb OCZ, but I can't be arsed getting x64 to work properly, as it is my daily/work machine, and Vista64 was a major headache.
Have also sourced a kick-ass 4850 1Gb card to upgrade my existing 256Mb GDDR3 3850 (which has been awesome to tell the truth).
You'll find that most cpu's these days have the 64 bit command set and most people are chomping at the bit to use more than 3.5 gigs of ram (old XP limitation). Windows 7 will primarily be 64 bit I'm guessing since a) most cpus for the last 4 years can do 64 bit and b) people really really want to use loads of RAM, esp with the new i7 platform having 3 way memory (3x2 is what Im getting, will have the option to get another 3x2 for the other 3 slots - 12gigs entry level is phenomenal...
The only driver issues I can imagine are older hardware and certain USB devices. Logitech has been notoriously shithouse for 64 drivers before but I'm interested to see how they treat their customers once W7 is out (I have logitech mice, kb, speakers, joystick, webcam etc - excellent hardware but the driver support (used to) leave a lot to be desired..)
Im really looking forward to this new system. has been 5 years since I upgraded - I'm rather proud of that, and my AMD3200/1gb/36gb raptor will make a sweeet linux box
oh and ive managed to scrounge a dds drive out of spare bits so I has me a tape backup unit too
Going for a cheap vidcard atm since all I play is world of warcraft and that should do it easily... will get a dual SLI beast later on when the next hardcore 3d shooter gets released no doubt hehe
-D
W7 x64 is awesome ive had no drama's with the release i used
this is the video card i bought at christmas time
>>gigabyte 4850 1gb OC<<
that's the exact card I'm running Steve........and yes Andrew, 64bit Vista is a real pain (never had this many issues with XP) but what else do you do if you want lots of memory?!
I just built my system about a month back and using this card: http://www.pccasegear.com/index.php?main_p...roducts_id=8103
That is the EXACT card I am hoping to get. Are you happy with it Vu?
If I get it, it will cost me $200 with 1.5 years warranty still left on it. And I should easily be able to get $100 for my 3850 (since it is an awesome card that plays Crysis at very high res with no problems), so it is a great value upgrade.
Yeah I'm happy - havent got a game I couldnt play yet! Can play Far Cry 2 and Fall Out 3 on max settings @ 1920x1080(max res) and crysis on the same res but with recommended settings. Although I just mainly play CSS anyways lol
Looks sweet as in the Antec 900 case aswell :D
In your case for $100 thats a heaps good bargain!
i understood about 3 words in that :P
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
