What ADSL router does everyone use?
I'm looking at getting a Billion 7404VGPX router, but have heard the N wireless standard is coming big... although, it's only JUST a standard at the moment, it might need more perfecting before it's released mainstream? I'm always a bit wary of buying bleeding-edge hardware.
I just need something that can handle ADSL1, Wireless, 4 port switch, 3G capable, VPN capable... and that's about it.
3G ? Huh?
I use a Linksys WRT54GS with hacked firmware (I installed 5mb version of linux on the 8mb flash and use the extra 3 megs to serve basic webpages)
Has been rock solid for 4 years, the new linksys N combo would probably be a good one.
Some of the integrated linksys adsl 2 modems from a year or two ago would die randomly due to poor quality soldering - theyve addressed the build issues nowadays (which is why they changed the housing of the unit so it doesnt look the same as the old ones).
-D
http://bc.whirlpool.net.au/bc/hardware/?ac...mp;model_id=816
There's the specs.
It has 3G support, apparently.
Edit: That's the 7404VGOX model, but roughly the same.
Right thats a combo modem. Does ADSL and HSDPA input (so u can use wireless broadband on it instead of ADSL)
Bit of a waste tho if you're going to stick with ADSL. When I move I'll be installing a PCI Adsl2+ modem in my linux gateway and running that off a UPS rather than having an alcatel modem plugged into the WRT54GS (its a wireless router alone, not a wireless adsl router - never been a fan of combo devices)
-D
i have a DLink wifi router and it is rock solid easy to setup has plenty of security features this came out that same time trial N came out
I'm into hacking routers and doing funky stuff with them. I generally use DD-WRT
Its very feature rich and lets you amplify the transmit signal strength. I've had my linksys transmitting 250mw (up from the standard of 28mw) but now I keep it at the 100mw mark. The cpu (broadcom embedded) is also overclocked from stock 200mhz to 224 and is rock solid without any cooling. The router runs a copy of apache which I use to serve files and also a webpage with my shoutcast server on it (router has 32 megs of ram, more than enough)
Next router I get will be an N but it'll definately be one compatible with DD-WRT... great package that...
-D
EDIT - Just did some looking around. The Linksys WRT350N looks to be like one hell of a nice router. 300mhz, 8 meg of flash, 32 megs ram, gigabit ethernet, hardware crypto for SSL and IPSEC, WPA2, N specification, USB 2.0 port for a HDD caddy or flash drive... you could have a lot of fun with it (or if you're bored, overclock it and run seti@home :starwars:
EDIT2 - or just put a USB hdd on it and run a lightweight linux bittorrent client... ooh la-la
EDIT3 - This is the one I have http://www.pccasegear.com/index.php?main_p...roducts_id=7263 except when I bought mine it was called the GS (linksys are really bad about changing product specs while keeping the same product name - so version numbers are important)... its a good solid unit. The broadcom chips are what u want, the vxworks wrt54's are all shite. And strike the first edit. The WRT610N is the shit - its not DD-WRT compatible YET but the hardware features are very nice, same as above but dual band (with 5ghz transmitter) and 64 megs of ram... you can run a mini-squid cache using the extra 32 gigs and save yourself a bit of bandwidth
Edited by Dohmar
bit over my head i hacked my phone and now its even more locked to three stupid 3 strikes your out now i have to try and flash it back to factory spec to see if that resets it or take it to nokia service center
ok for those wondering whats the hooha about Windows 7 here is a tech demo of Win7 RC
click on the medium screen for best view
http://technet.microsoft.com/en-au/windows...x?ITPID=tnflash
and a bit of a laugh for a windows ring tone
http://www.zedge.net/ringtones/320863/wind...music-ringtone/
Scratch that!!! Now I've hooked it up at a better speed, will arrive in about 32 minutes :D
i hate waiting for cash to upgrade
its been 5 years and now ive finally decided to upgrade i want to do it >yesterday< but have to wait 6 weeks till I pay my n1 turbos off
oh woe is me
bring on the tax return bitches
-D
im pretty impressed with win 7 RC (build 7100).
only hassle i have had is MSN was not logging in, sorted that and im sold on it. will be buying it when it comes out (first time in about 8 years actually paying for software lol)
what dont u understand?
-D
This part.... I'm guessing it wasn't directed at me now :D
oh woe is me
-D
yeah im loving it Carl i also just found in Enterprise and Ultimate they will be offering VM for XP
see more |>>Here<<|
nice! hope they bring one out for s2k3 so i can use that for testing instead of having 2 pc's running with no KVM (my desk is the definition of clutter).
its pretty good that alot of the features on win 7 seem to be derived from applications and modifications that ppl have installed made to XP and vista. Its refreshing to have a product that is the result of a company listening to consumers, rather than dictating to them
nah it wasnt
i have bought a pair of blown stock gtr turbos and im paying a dude to recondition the entire thing and use steel turbines and build it to "better than" N1 spec.
means i get better turbos that are semi regency friendly (they check housing numbers, they dont take turbos off and check turbines ;P)
and the upgrade = computer upgrade. ;P
-D
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
