Win 7 already like Vista has proven to me that it can lick my balls. :)
Seriously if Microsoft are going to continue to build this bullshit admin control into their OS'es I'll happily f**k right off back to XP and OSX. I absolutely refuse to be treated like a computer newbie/moron and have restrictions put on my OS.... and before you fans of 7 get here and tell me to turn some bullshit UAC off (doesn't work anyhow)..... my point is I shouldn't f**kin' have to!!!! :D
you wouldnt like any form of linux then would you. Stick to a mac much more noobish
How is OSX noobish?
If you think it's acceptable that Microsoft want to control what you can or can't do with YOUR OS then that's good for you. Not acceptable to me!
So unticking UAC is to hard for you folks, thats one check box is a real noodle scratcher isnt it.
Maybe you didn't read my post corectly.... Unticking UAC (maybe you're reffering to UAC 'Never Notify' at it's lowest setting) or even running command or .exe as Administator (and I am the Admin) doesn't work, if it did I might not be so pissed about it. The fact that I would have to do this at all is crud!
Error messages stating I don't have necessary permissions. I'm over it and will boot my XP drive now.... :D
I'm a linux engineer so I'm biased, but have you guys ever tried Fedora ? Its one of the best distros out there and has come a long way from when I first started using Slackware back in the late 90's
I dualboot F10 and XP on my asus EEE. the F10 is so much faster, so I use it whenever I don't need to - sadly some things only come with windows drivers so it doesnt have the same level of support as windows, but for a lot of folks its at the stage where they can use it. And its FREE.
And if you don't like unix-like operating systems, there is always the Haiku OS
It's based on BeOS which was a serious player in the multimedia section up until Be Inc folded late 2001 after a disasterous focus shift to 'Internet Appliances' (basically cloud computing and lightweight hardware - they were 8 years too early unfortunately).
Haiku is built from the ground up, is pervasively multithreaded, object oriented and open source (and hence Free). It has the ease of use of MacOS but at this stage is still declared 'alpha' quality but only because the code hasn't been tested on all hardware. So far its pretty much rock solid in everything it does, and very very lean on resources.
I remember when BeOS came out and they had p2-400's and voodoo2 videocards... one of the early demos was to run an openGL cube and superimpose a unique movie file on each face while the cube was rotating... it used I think around 20% cpu due to the super efficient way BeOS deals with media streams...it was way ahead of its time, and while Haiku is a replication of this technology and so doesn't have many 'modern' features, I'm confident the 2nd release of Haiku will be world class. Try it out, even if only on a VMware console and give it a go.
-D
my uac turned off fully, no pop ups at all... im convinced by win 7, it got off to a much better start than the enterprise version of vista ultimate that i have.... i think it was vista ultimate BSoD spec
lol, if Microsoft keep going down this vein and line of thinking, peeps are either gonna head back to XP or like you said, MAC!
some good lol's in this thread atm
UAC is a good thing if ever you've seen my dad on a pc and other complete noobs its something you know we need, not we being me but we being other hopeless users
I'm certainly not someone who needs UAC or will tolerate it.
Steve your not asked to tolerate it just turn it off
As Karl has said its easier for a pro to turn it off than a noob to turn it on
And you know this has come about from the likes of kazaa and bear share mum and dads would download the latest cracked something but they really get a virus
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
