after being told it probably isn't worth fixing my laptop, im looking at new ones.
http://www.harveynorman.com.au/products/in...-new-range.html
Looks pretty good for what i use it for, 2.0Ghz Core 2 Duo, 4GB DDR2 RAM, 512mb dedicated graphics.
Why not try and find a replacement screen on ebay and replace it yourself, it isnt that hard, if you dont feel comfortable to do it yourself, i can do it. Replacement screens go for about $150-$250. If ya need any help let me know, i have been pulling laptops apart at work recently as our store has started doing minor repairs.
Unpatiently awaits for the 'decent' 120 odd GB SSD's to drop from the 600+ price range. :rolleyes:
The degraded over time write speeds appear to be sorted with the higher end SSD's via their TRIM/WIPE programs (until Windows 7 that is) now the wait for the price to drop.
cheap ones are inferior to a server card
hence price difference
only because theyre hardware accelerated - which is really only an issue when you're dealing with MAJOR bandwidth transactions (as steve alluded to) or if you're an anal FPS gamer who wants an extra 2 fps (and about a quarter of the ethernet latency - which means SFA unless you're LANning it up)
i think there was a game company making hardware based cards, they were around teh $150 mark for gamer nuts... server cards will still set you back more
IMHO you can't go past the realtek 8139 series if limited to 10/100.... really good driver support and dirt cheap ($7 or so)
-D
I remember an add in some PCPP mags, of a ninja holding a gaming network card....ummmm, was called....Killer. But i don't reckon you would see much difference between a $20 10/100/1000 and a $200 gaming network card for normal everyday use, with a bit of lanning. As for server work, yes i could see a difference there, but why go to that extent for just basic use.
anyone got an external DVD drive I can borrow to install Office on my laptop......the internal one is playing up on this particular disc but the disc is fine on other PC's.
Funny thing is, the laptop plays other discs fine.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
